Leather freezes your ass in the winter and burns your ass in the summer LOL!
if your leather seats aren't heated and your windows aren't tinted, then I'm sorry, nyukkuh you poor!
fk that. i'd put a lot more k's on a ferrari if i could afford one. whats the point if you dont drive the thing?
italian cars, lots of kms... does not compute. (unless they have ze german engines ie. Lamborghini)
point is to tell people you have one
yes they do... hey have a book...
but purple/purple will probably suffice
tell me more about this book. Stock injectors are red and I've got purple ones in now :mad:
which EPA had this book? Was it moorabbin?
Reading the EPA there is no law againts replacement injectors, only larger ones...
Spill the beans about said book!
skyline is outside :ninja:
been dreaming of this since i was 12 ahahaha..
drove it around for a bit and my god! its such a difference from the 4wd's im used to.
Congrats, even when I go outside to the driveway I still get that feeling of awesomeness, feels good mang. I'm sure most people here agree and love driving / owning there cars :mad:
skyline is outside :)
Enjoy it whilst you can cause once the cops arrive to the party you'll soon give up and buy a golf! :down:
lawll ill apply for an exemption, and if that backfires, i can get my employer to write something out
It doesn't take a lot of effort to find something unroadworthy/illegal on a skyline. Your restriction is just another headache ontop haha.
lol, he wont listen to anyone his like me when I was that age, I was a fraction away from buying a 32 GTST but good thing I didn't the first week of owning the N/A got pulled over and checked for turbo etc.
All the best with it Mohsen, if you get f**ked by cops just buy another car straight away.. keep the 32 in the garage for 4 years. Then it will only be a 25 year old car :down:
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
