I was on my way to bunnings when I saw him, saw him pulled over on the way back - seemed to be about 5 people in the car from the number of people standing around with the cops, so plenty of helpers to get stuff off
prob dumb question, for the deca they require a fire extinguster in the car. But they they check if its been checked? I just bought one and not sure i need to get it serviced to get the stamp on the thing...
Well, today marks the 1 year anniversary my car disappeared into a workshop. I should go there and bring it a cake, or something. Actually, that'd be a really funny way of making a point, lol.
Anyone know of any shop that knows their way around R34 Triptronic wiring setups
Have tried/Enquired at:
RE Customs
Status
Sabbadin
Chasers
Racepace
Knox Automatics
Dr.Drift
(going to call the last couple in the sticky today)
May have to send the car to MV Autos in South Australia on a truck. Any info that leads to this getting fixed will be rewarded with a carton of a beer of your choice and/or equivalent spirit. :D
Convert it to manual?
+1
Auto is gay.
Daily. Spent a ton on a shift kit from MV autos. I generally like the ability to just put it in D when I just want to get around town. Its an option but f**k me its an expensive one especially if it's not necessary :D
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
