I was on my way to bunnings when I saw him, saw him pulled over on the way back - seemed to be about 5 people in the car from the number of people standing around with the cops, so plenty of helpers to get stuff off
prob dumb question, for the deca they require a fire extinguster in the car. But they they check if its been checked? I just bought one and not sure i need to get it serviced to get the stamp on the thing...
Well, today marks the 1 year anniversary my car disappeared into a workshop. I should go there and bring it a cake, or something. Actually, that'd be a really funny way of making a point, lol.
Anyone know of any shop that knows their way around R34 Triptronic wiring setups
Have tried/Enquired at:
RE Customs
Status
Sabbadin
Chasers
Racepace
Knox Automatics
Dr.Drift
(going to call the last couple in the sticky today)
May have to send the car to MV Autos in South Australia on a truck. Any info that leads to this getting fixed will be rewarded with a carton of a beer of your choice and/or equivalent spirit. :D
Convert it to manual?
+1
Auto is gay.
Daily. Spent a ton on a shift kit from MV autos. I generally like the ability to just put it in D when I just want to get around town. Its an option but f**k me its an expensive one especially if it's not necessary :D
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
