I don't trust 2nd stockers, I do trust 2nd aftermarket turbos providing it is in good condition before it is being whacked into the motor.
and how do you know its in 'good condition' before whacking it into a motor?
I bought a hks2530 off yahoo auctions. Came in its original box and manual. No shaft play and looked good as new. Whacked it on the car, started it up and all you could hear was bearings screaching.
Rebuild revealed a flat spot on the bearing. Luckily cost of turbo + rebuild was still cheaper than the price muppets sell them here for
Selling my roof spoiler, $120 if anyone on here wants it, just took it off my car. Need to put an ad in the For Sale section but cbf right now haha
ill give ya $2
did ya see my other post a page back bruuu ps i was @ wbee plaza today what a fkn dump forgot to see if u where working but
Dude i saw you AGAIN on saturday night! stomping down collins st haha
hahaha did you call out my name? I swear my friend and I thought someone said my name but didnt see anyone around!
No time for rest, why arent you out tonight? My friends are without me :( I got early wakeup (5am) ~_~
So whats goin on in ere'
That rex is f**king nice.
That R34 wing / wheels on the last page look lame IMO
Whats a cheap place to get canards from?
And Shan give me a job kthx :D (no but seriously if you work in I.T know of any going?)
By turning the turbine wheel with hand, if it's smooth, good and pull front + bac and side by side for shaft play.
Done that twice, both pair of turbos have no issues and is pumping 300rwkw+
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
