Bloody Mac users :laugh:
PC FTW!!!!! mac sucks...lol...
Meh I give up.
No pics for you Jamie...
GAY!!!!! come one grant organise it asap...want to check out ur new beast....cant wait... :)
saw andru tonight playing with GTR 010 on the prinny... i was in a taxi home after merowyn's work xmas party
Yea Josh beats adru. Andru can't put down the 400rwkw. Joshs is running 320awkw now but is maxing out Afms at 350
rimon most auto places would have this i would think
as long as you match the thread size and pitch a generic part would be fine
checked Autobarn and Repco they dont have em. they only keep useless shit that you'd never wanna buy...
sandwich plate isnt so hard to find but the sensors are proving to be a mission :/
also, sick of shit kunts calling/texting me asking if my car's P plater friendly :ermm: maybe try reading the car description first :domokun:
/rant
15.5k for 270rwkw 32 V Spec.with RWC.
Mods are the following;
R34 N1 turbos + dump pipe with HKS actuators.
Power FC.
Nismo Front pipe,
3" Hi flow cat.
3" Cat delete pipe
Apexi N1 cat back.
Apexi RSM.
Apexi pod filters.
Pair of Recaro SR3 seats.
Tein Coilovers.
Whteline Swaybar (F + R)
Adjustable cam gears.
HKS EBC (EVC4 i think).
Apexi Pen turbo timer.
Nismo Gearknob.
17x9 +19 SSR Evolution Wheels.
Have standard exhaust, suspension, airbox.
Did you buy that off Antstar? I lent him some standard GTR bovs for him to pass a defect. Hasnt returned them since then :/
Nope, he sold it before I contacted him.
That slammed GTR is awful. Never should a GTR be slammed and have stretched tyres. Never.
On a different note, anyone ever driven a VW Jetta? Just like a Golf? Wouldn't mind one (being in the market for a new car) and this has given me some more inspiration
  • Like 1
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
