15.5k for 270rwkw 32 V Spec.with RWC.
Mods are the following;
R34 N1 turbos + dump pipe with HKS actuators.
Power FC.
Nismo Front pipe,
3" Hi flow cat.
3" Cat delete pipe
Apexi N1 cat back.
Apexi RSM.
Apexi pod filters.
Pair of Recaro SR3 seats.
Tein Coilovers.
Whteline Swaybar (F + R)
Adjustable cam gears.
HKS EBC (EVC4 i think).
Apexi Pen turbo timer.
Nismo Gearknob.
17x9 +19 SSR Evolution Wheels.
Have standard exhaust, suspension, airbox.
Sounds good man!
The standard air box you have... Do you have the whole setup including the cold air intake?
The part that slides into the part under the head light?
If you are interested in selling it, I will want it as I am going to use it for a modified CAI.
Sounds good man!
Yes I do have the whole she-bang, not interested in selling it at this stage.
jetta is good my parents have one, drives nice what about accord eurO?
That's another thought, but IMO the ones around my price range are beggining to look a little dated, as compared with the current model. With the Jetta, even a 06-07 is still the same shape as the current model. Plus that chrome grill looks sexy :D
More inspiration:
18x9.5 +24
18z11 +20
Half of boot is fillwd with dynmat, need to remove them along with wires for stereo...
FCC3 Handcontroller doesn't work with RB26 based Power FC, need to buy FCC NT or something? Need to look few pages back or just PM Paul.
so just dont modify it more till you can aford it douchebag
lolz
its like when people say "need to sell car to invest in property" or whatever.
if you cant afford to keep your car you shouldnt even be looking at moving out or buying property coz chances are you wont be able to afford that anyway.
  • Like 1
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
