ok hang on so the $2802 is what i pay per year and the "excess" which is $1600 is what i pay in an event of an accident etc? 3046 much safer than 3047 :P
what do yous pay then for your premiums?
With Shannons, Rating 1;
Cube - daily use cover, Skyline - extreme limited use cover, Pulsar - laid-up cover, approx. $170 per month.
If one's ecr33 diff has gone from a twin spinner to a single spinner akin to that of a VN commodore, what should one do?
options are:
shim
weld
replace with GTR diff
replace with real diff
all of these better than standard diff
options are:
shim
weld
Replace with GTR diff you say?
What benefit would this have over say, a train... which i can also afford.
options are:
shim
weld
Shim = what i will be doing
Weld = f**k that
GTR diff = will need to replace both half shafts as GTR is 6 bolt and GTST is 5 bolt
Replace with real diff = expensive and if u buy a shit one like i did it will explode nicely LOL
$10/month X 12 months = $120
is this your r33 or? why so cheap you must have a spotless license or something..
u think thats bad i remember being quoted somewhere round 5-6k full comp back in 2003 as a p plater r34 gtt think just cars or shannons.....
now $290 third party just cars.....
not surprised for a p plater i dont know what p plater would be able to afford that just for insurance anyway
thats not too bad for 3 cars but why do you need 3 cars for :/ i can understand 2 if you had 1 daily in which case i'd get a shitter thats not even worth insuring so i'd still only pay for 1
On a scale of 1 to Miley Cyrus, how illegal is shimming a diff?
you can shim a diff as tightly as you want, you can shim it for minimum lock or shim it so that it skips like a 2 way. Up to you.
With legality, its like anything if cops see it skipping they might say something, i have never had a prob with cops with the 2 way, they saw it skipping along the ground and didnt say anything
options are:
shim
weld
just went out for a drive to prac my heel and toe technique.......master :whistling: i notice that my diff feels a bit sad maybe its these f@#%in ku36's dnt like em time to get a real
diff nismo 1.5 or 2 way? yea boiii...
3 litre is probably cheaper
f**k welding the diff or GTR diff
either shim your current one or new kazz centre or nismo centre
do it once and do it properly
stuff changing in / out 2nd hand parts etc
kaaz 1.5
do it and you can thank me later.
shimming's good fun if you own a beat up 32, but if you want it to last, do it properly. Put it this way... ALL the power you make has to go through it. If you wanna wager that on a $1.50 shim go nuts.
shimming just increases the bite point of your viscous, which means there's still slip, as time goes on it'll wear down and cark your diff. Guaranteed. Unless you're prepared to pull down and flush pumpkins after every track day or major fang session.
kaaz 1.5
why kazz? they better?
??? how else do you drive around? I heel/toe for daily driving.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
