I do, but I have a SERIOUS saving problem. Probably make about $1200 net per week, but just waste it on crap. (Plus rent and shit). Getting a new car will just make it worse :laugh: Just do some extra overtime when it surfaces I guess lol
i will have sex with that car
just watched an episode of that chop shop
corners cut galore
they supercharged and tuned an old school porka to put out 300hp atw without even tearing down the engine to make sure everythings okay...
you know, 20 something year old engine is gona be fine jumping from 160 - 300
  • Nope 1
i get $200 a week :)spotted a toyota camry with GTP badges, didnt know FPV were making camrys...andpost-31699-0-02058300-1295074546_thumb.jpg
f**k domestic.
Apparently I get 1250 a week net :\fuck... where does it all go? surely I can't be spending that much on cocaine and hookers.
Thought you'd be on a shit load more than that...I make that and I don't even work 40hours a week...
5244256151_4921f3bc29_b.jpg5249810498_e6a3971335_b.jpginstant bonerthis
599XX PORNO
Anyone that minds me quoting those pictures is a cock sucker.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
