As if you'd come all the way out here for a steak...
You're welcome to come the next time I go back for the 1kg challenge though..
Like
Got the 500g rump to sus it out before going back next time for the 1kg challenge. finished it in about 13 minutes including the chips coleslaw and salad (you get 30 minutes for the 1kg challenge) without really rushing, so I think I can complete the challenge...If I do, that'll be a 1kg Rump (which was quite nice) for $20. Can't lose.
so you recommend?
so you recommend?
Well the rump I had was decent, so I'd assume the rest of the cuts which are generally better would be good...
One mate had the t-bone and rated it, 2 others had the mixed grill, gave that the thumbs up...And their mrs' had a parma, said it wasn't the best, but I personally wouldn't order anything other than a steak at a steak joint...
f**k me some people are so stupid. 2 way road, single lane each. dotted line, slow driver infront of me
over take at about 50, limit was 60
so i speed up to overtake, the idiot speeds up too so i cant pass
i want to see the full vid of this please.
did some plastic welding on the weekend with some help from one of Bez's recommendations in Cheltenham.
Golf's ass will now be butter smoooooooth. none of this gaybo vent shit that the stock R32 bumper seems to have. Filler piece sourced from a VN Calais :/ Feel dirty for having holden pieces on my car, but felt good choppin one up.
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
