My mechanic was insistent that it would work better with the clutch I'm getting. So I just told him to go for it.
I was going to get one anyway. Less drivetrain loss :)
Car is predominantly a daily, but used for hill climbs and track days too.
Trying to get a good balance between looks, performance and practicality/reliability.
flywheel is a waste of money
I dunno, didn't really like the feel of my Exedy HD, so thought the cushion might be a good change. Spur of the moment thing :P
haha the cushion button isnt all that good for daily driving :P
takes a bit of getting used to, Kris drove my old 32 with the cushion button and even he said was hard
took alot of abuse though, and only died when one of the springs popped out of the centre part, apparently its a common issue on them
Haha good call. He's actually not making money off the clutch. That's the price that his wholesaler gave him. It's a bloody good clutch though. Definitely overkill for what I need but meh :P
HDCB's are terrible for taking constant abuse (like a full track day). The centre and the ceramic are attached so you can't rebuild them modularly when they wear out, they suck for daily driving and are no more durable than a regular HD.
basically HDCB's are for people who want to feel like they're using a brass button without any of the durability or benefits.
You either buy an HD which is cheap to maintain, gives good grip and slips enough to daily drive, or you get your balls in a bunch and buy a brass button. HDCB is for fags.
Heavy flywheel + snappy clutch = good
Light flywheel + snappy clutch = shockloaded drivetrain
I run an exedy lightened wheel in mine, with a 5 puk. Love it.
Fantastic for track work. Doesn't get driven on the street a whole lot, but when it does its a ball.
To be honest I didn't notice the difference between gears, there is a definite pickup in revs while while under load though.
leigh fix coilpacks and then check it, if the coilpacks misfire i wouldnt bother trying anything else. Where do u live? Do u want me to check it
yeah i'll wack coilpacks in first and see how it goes. I live near Knox but yeh will see how the new coilpacks go first
this.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
