So far I've had GTCs / Challenge F-zeros (didn't like them) / Grids. Decided to sell the F-zeros as well because the tyres were gone and didn't like the rim style so got some grids + 265 falkens for 1k (all brand new) and loan was all paid off. And now I'm unemployed so yeah.
So I got the following on the way:
Splitfire coilpacks
100k service kit
HKS panel filter
fuel filter
tomei cam gears
hopefully they arrive by the end of the week :D
I decided to replace my radiator when doing 200k service. However that led to months of headaches as i tried to squeeze in a 52mm rad haha
sideskirts!
yeah makes the car too skinny without them. Thinking of the r32 typeM sideskirts (if i can find a good set for sale) but it sometimes doesnt look nice from certain angles. Looks tacky as its stuck ontop of the rear panels and doesnt really blend in with the body work.
Got some rear pods already, just need to find some sideskirts
Went to the car meet at knox, the monthly one with all muscle cars and shit. As I drive out theres like 50 people just staring and egging you on to do a burnout lol. One guy yells out "nice GTST BRO" stare at him point backwards as I turn left so he can read "Oh GTR, NICE BRO!" bahaha
Turns out just as many people taking photos of me and my mates 32R rather then all the old school cars
would these work
http://japaneseimportspares.com.au/exteriorbodystyling/2
http://japaneseimportspares.com.au/itemdetails/3943
im just about to order some stuff for myself lol can get em packed with my shit if they were a go-er haha
My sister has less than 1k saved and a passion for minis. We discussed this already.
i meant has she even had a look at it?
wouldnt wanna drive all that way when my car sells to come back empty handed
going by the above what do u think?
No she hasn't.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
