what did he do that was worth 500?
Removed old gearbox. Installed new gearbox, clutch kit, lightened flywheel, replaced shifter cables and speedo sender.
New driveshaft boots.
Oil leak fixed + oil change (including gbox)
And some other stuff which I can't remember :P Will check the receipt later. Fair bit of work for $500, which is what some other mechs have charged me for like 4 hours work.
Edited by jezza boii
imo, cars wit that much poke look good from that angle.. that is all
ridiculous from the back, ridiculous form the front.
says the habib rolling in a sedan with hobo spec suspension.
and by hobo spec, I mean when you park the car at night, hobos climb in the gap between your wheel and fender for shelter.
usual rate is about $25 an hour, so he spent 3 full days working on your car?
Usual rate? Lol you need to check a shop that isn't your cousins. It's sometimes double that
any mehanic/tuner I use charges a std rate of at least $100 per hour (doesn't mean i pay that, but it's what they charge)
And Femno charges me around $40 an hour. I think shan is loosing his marbles cuz he seems to be posting crap (more than usual) these days haha
haha yeh depends on the house, location and most of all the sellers motivation. If you see somethign you like link me i may have a contact within the agency selling it to get you a no bs idea on where its at.
yeh that happens out east and inner west a fair bit its bs its all private sale where i am thankfully - much easier for buyer /seller. You can grab a bargain at auction though particurarly when the market is favouring buyers like now.
cheers bro. The ones ive got my eyes on are all auctions so will have an idea of the pricing once the bidding war starts. First one this Sunday, so we'll see how it plays out haha
Well my mechanic tried to spin both wheels. The left one spun. The right didn't.
Turns out the handbrake was on BUT wasn't functioning on the left side so he got confused.
awesome mechanic :down:
+1 too much poke.... but i'd also like to see a lil tyre on the lexus....
showing a little tyre is needed imo
also awesome firework
http://www.youtube.com/watch?v=m95mvMVGQ-0
  • Like 1
car sounds pretty mangled
other than your sig what is wrong?
Not much. Well other than the hilarious sig, the fact they have to get it to run with a piggyback ECU. But it's safe to say 99.9% of the issues are actually electrical in one form or another. I guess I'm just looking for someone who understands that wires carry electricity and as long as they carry it to whatever sensor is looking for what, it should be OK.
Apparently 'tis not that simple.
My local guy is $50 according to my last bill ;)
I take everything i need for service/want changed. Pick it up the same day. Works out well.
Guy works with a lot of race teams and is in Europe a lot, was @ bathurst 12hr for instance :D
Good that I've finally found someone that i can trust locally AND clearly knows what he is talking about
Obviously still get Chris to do the major stuff. But general service type of thing, cant go wrong and it saves me 1.5hrs on trains + the drive there/back etc over 2 days.
lol classy..
jersey shore sounds queer
that dude in man vs wild is a f**king machine!
nah good show...
bear grylls enjoys drinking/bathing in his own urine way too much
haha that's f**kin sick
Apparently dtf originated from superbad. Either way, I'm making dtf shirts if anyone wants em :P
Original
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
