The Grill Room, i posted early in the thread etc - It used to be a Squires Loft, and then went out on their own years ago.
So it's certainly "up there".
Been to the CBF Squires Loft a few times myself, very good venue also.
LOL @ Pub, everytime i've had a steak @ a pub - asked for Med Rare, it's come out with only a slight tinge of pink in the middle.
You get over trying to have an argument with the staff about how it's not Med Rare and some 17yo comes outta the kitchen to try and tell me I'm wrong :D
Agree, never had a bad steak at The City Grill Room. Highly reccomended.
Edited by llama_au
what should i do wth my car
lots of things wronhg with it :(
would rattle of a fair $$$$ fixing it all
almost too much wrong to sell as well
ho hum
What's so wrong with your car? I could get a rwc on mine straight away no probs :s
just general wear and tear given the kms it has
i mean its in good nick considering
but yeah some things need work
wheel bearings
diff
tyres
wheels need paiting
engine refresh
paint touch up
wheel bearings
diff
tyres
wheels need paiting
engine refresh
paint touch up
Weigh up how much to fix it all.
I bet parting it out might be an option
yeah i mean it will keep going
but i would like to fix some of the things
ie the wheels are farked
the diff is hopeless
engine is tired
anyhoo we shall see
gonna buy another daily so will have some options
ho hum
park it in a river
When i can stomach paying more than 5-600 for a radiator i'll consider it >_<
my alloy radiator was like $300ish from memory, couldn't get the car to overheat if I tried :)
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
