Wow!
She sung about getting up in the morning, going to school and waiting for the weekend...
Then sung which day comes before and after each other...
Lyrical content = FAIL!
Was a good :laugh: though.
dont know how to break it to you man, but top gear is a TELEVISION SHOW!
it was designed to be commercial, an has been since episode 1. they have NEVER had any worthwhile technical info, and they never will as that wouldn't rate.
5th gear is even suckier. people who say it's the show for enthusiasts need their head examined.... it's just a second rate topgear, with an even more overtly gay presenter (although he is a much better driver)
and dont even start me on the other 2 homo's and the woman....
5th gear segments that dont involve tiff ALWAYS result in me changing the channel...
did you go see topgear live?
Their focus has changed from delivering car information to entertaining the general public with no knowledge of cars. When a woman or 10yr old kid say they enjoy watching Topgear you know that Topgear has lost the game. This was never the case a couple years ago. Proof of this is when ch9 purchased it because they saw the growing popularity amongst everyone, else it would have stayed on SBS as it has for many years.
Just watch any episodes from a couple years back, theres a reason why ch9 doesnt play any of the older episodes.
Unfortunately with all fads they will soon drop off. Gordon Ramsay, Bear Grylls and now Topgear. Look forward to 50% off Topgear merchandise at Target
I'd imagine their budget is ridiculously high, and without ratings they don't have shit. Technical info about cars that the audience can actually afford is boring as bat shit, which is exactly why it's not part of their show. Their tests and challenges are ridiculous for a reason, people enjoy watching that shit, which gives them the ratings and budget they need to keep going.
Just looked at 300rwkw R33 gtst (turbo is Blitz K5-660) goes pretty hard, in coming days I'll contact the mob who built it as the motor is forged (seen the receipts).
Noticed couple of things, there's a sensor on inlet pipe (next to BOV which is blocked) and pink label afm (it's R33 S2 and running on Power FC), hence my curiousity.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
