Yeah, not many of these and Characoal one pretty much as rare as hens teeth especially in series 3.
Same goes for 33 GTST that doesn't have RHS guard hole to accomodate the FMIC piping. Not many RWC place will give out certificate for the hole.
For first time I'm struggling to purchase a car.
My car has had plenty of rwc with the hole :s
If you're so set on midnight purple, buy a white one and get it sprayed whatever color u want. Who gives a f**k if it won't sell for as much as a factory midnight purple if all you want is the color.
Thought about that when I had the white one, was quoted $7-10k for a colour change and decided to f**k it. For this kind of money, I can buy turbos, PFC, wheels, coilovers, blah blah blah...
Only good thing about R32 GTR is, many of them are in Gunmetal Grey which is a colour I like most, yet I bought black one...
that sounds silly.
everything i read compared to what its doing says coil packs and or spark plugs hedging bets on somethign not right with the plugs maybe not in right or gapped wrong dunnno only a week old since it was fine before that im hoping its that
either way im gonna give it hell @ winton haha
Have you tried a different coilpack loom or ignitor? These can also be responsible for the misfire.
took car back they wound boost T down they rkn that was causing the problem so need new boost controller
This might fix the issue but only by masking it. Could be an underlying fault in the ignition that only shows its face under higher boost.
man im gettin over checking into wasteland
it salways same shit cant sell my car, buyer fkd me over, cant find a car to buy, oh didnt buy that car it was shit cos XXXXXXXXXXXXX
more importantly winton was fkn awesome car was really solid all day
Birds - yeh car is going back friday for more changes to get it right dont need it for a few motnhs now so was just about getting out there yesterday which i did so :D:D:D:D
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
