ah sucks :(
noticed a fair amount of shit drivers lately
theres been a stack of accidents this week, i seen 3 cyclists get knocked off in St Kilda yesterday. was kind of funny they just lay on the ground and wouldnt move like they were playing dead, blocking of most of Beac parade in the process.
Damn pushbike riding drama queens Pretty sure there was nothing wrong with any of them, there was no blood or anything even the guy that hit them appeared to be laughing a little as he called for help..
Probably had their shoes still stuck in the pedal bolsters and couldn't get out!
Kind of like any AFL umpire that gets bumped and falls over like he's been shot in the brain...
Particularity the one from the weekend just passed, can't remember what game it was but after the center bounce he copped a slight knock from behind and went down like a dead man, stayed there for 5 or so seconds and then got up and appeared seriously shaken....
Unlucky for him they zoomed in on him when he was on the ground and he looked fine, looking around like a hurt child waiting for attention..
If anyone finds the video of that or similar incidents, please do post them up.
haha, nah, i think they just wanna make the scene more dramatic than it needed to be, possibly there way of protesting for cyclists rights or something..
cyclists don't have right's... they should all be run over as a matter of course
Go to YouTube...type in "soccer".
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
