He had a widebody MR2 before the RX7 lol. It wasn't really my taste. Resprayed in pagan gold, black bonnet, sunken wheels, autosalon spec interior.. And less power than mine :P He obviously matured a lot when he decided to modify the RX7!
maybe that was it, either way i remember it was shit as
Any cheaper and I think I'm going to have to consider buying it...love that colour. Drive away no more to mod. Shame he did what so many twits do on car selling websites and put up 11ty pictures of the same stupid front oblique angle...ZERO pictures of the back...and only one of the interior.
lol...maybe it should be, live your life within the confines of the law.
Anyway, enough talk of young girls for now...topic is now chocolate.
I'm thinking Cadbury plain or Coles brand Belgium takes the cake for best block form...and tough call between Guylian and Lindor Lindt for the fine/boxed stuff. No wait, Duc d'O for the mofo win. Too many good ones. Thoughts?
haha cadbury ftw, but my opinion is biased :P
Still have that 10kg block of Cadbury chocolate I won couple months ago. Have no idea what to do with it, cause once its open I aint going to eat 10kg haha. Might donate it to some primary school.
If school donation fails, best answer on SAU wins*
*will probably not win
Isn't it in 10x1kg blocks inside the big packaging? But srsly stop toying with the emotions of chocolate livers everywhere and either eat it or give it away to someone who will lol
Won't that shit (read: heavenly gift from the gods) eventually go off?
haha i think best before date is June/July.
its five 2kg blocks. Need to find a good cause to give it away, unless Ham wants to cook it up for sau? haha
I was thinking the same thing. You've had it a fair while Pat, and I'm betting you didn't buy a custom fridge to put it in :P
kept in temperature controlled area of house, s'all good
I'm on day 10 of anti-fat bastard project and I would kill a man for that chocolate. Literally, I would kill for it. I would cut off a motherf**ker's air supply until he passed away.
Give me the chocolate.
Is Astro Bear gonna have to choke a bitch?
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
