This probably sounds like jibberish in a car forum but my quick action throttle came today! HOORAY!! And my race glass! YES!!
Monday and Tueday are both track days at Phillip Island, 24 and 23 degrees, perrrrrfect. Quick action throttle will be sooo helpful in getting to redline in sixth gear faster. Yes yes yes yes yes.
Haha I love your wheels. You're probably after a nice figure too tho
im justgunna chuck this out there, i dont expect alot of support.
But am i the only one who thinks blags car looked better with the old wheels. i mean the enkeis are awesome but the car looks fat and bloated with them, whereas it looked more sporty before
so whos with me?
I realise this is a page or two back, but I've had a flu bug so I get to have my say now :P
1. Facebook is Myspace all over again, for stalkers and people who think other people care what they are doing every minute of the day. Myspace was for people who didn't know how to build their own website but wanted to put themselves on the Internet.
2. Time is money, outside the clock or not. There is nothing stopping you from working a job every hour of your waking life - some people do.
3. It's not homo until you're masturbating over, kissing or sexing someone of the same sex and deriving sexual pleasure from this. Anything else is just hate for someone doing life differently to you or having different ideas on how to attract a partner. If it works for them, who cares? How does what someone else does in their spare time or in front of the mirror bother you so much?
4. Everyone is "shallow". It's a moot word used to describe the basic instinct of selecting a mate based on appearance. Incidentally, aesthetics are the first thing you are presented with when you meet someone and therefore the first thing you judge them on before you talk to them. No one's dream partner is short and fat with no hair, a disfigured face and a ratty sense of fashion. Appearance is everything. You're all shallow motherf**kers, deal with it.
5. Something about someone not having sin and being able to throw the first stone. *cricket chirps*
6. Each to their own.
7. Damn you rock em sock em robots, can't we all just get along?!?!
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
