Mad? lol please.
Just the most overrated Jap wheel on the market IMO.
LOL!
One of the best wheels to come out from Japan :D
The TE37SL doesn't look too bad, i just prefer wheels that are a bit more rare, give the car a bit of personality.
TE37SL are the same, just different colour and yes, rare wheels are great too.
Especially old school style wheels, adds a nice touch.
T & E VERTEX BODYKIT
MIDNIGHT PURPLE RESPRAY (MNP1/LP2)
JDM-SPEC SR20DET ENGINE
HKS GTRS BALL BEARING TURBO
HKS UPGRADED TURBO ACTUATOR
TOMEI PONCAMS (256IN/256EX, 11.5MM)
TOMEI ADJUSTABLE CAMGEARS
NISMO 740CC INJECTORS
WALBRO 255L/HR IN-TANK FUEL PUMP
Z32 AIRFLOW METER
APEXI POWER FC ECU
ARC SUPER-INDUCTION POD FILTER
ARC TURN-FLOW INTERCOOLER
HPI DUMP/FRONT PIPES
HKS HI-POWER CAT-BACK EXHAUST
OS GIKEN BUILT 5-SPD GEARBOX
XTREME 5-PUC HD CERAMIC CLUTCH
HKS HIPER D ADJUSTABLE COIL-OVERS
IKEYA FORMULA ADJ. CASTOR RODS (FRONT)
CUSCO REAR CAMBER ARMS
RAYS VOLK TE37 FORGED 1-PIECE RIMS
Fronts 18x9.5 +12
Rears 18x10.5 +22
Looks like a S14A (Kouki) to me...
S14A fronts look so much better then S14 fronts.
There was a point where that thing was a .5
Also, overheard a couple kids at the shops talking about what cum tastes like, then one of them goes "mahmoud tasted his own cum, he Sed it was ugly"
Lol wtf
I'm assuming you stepped in and corrected em on what man cum really tasted like?
douchebag
Aah yes i remember that thread, I'll check it out. I meant as in, that genuine jap drift kind of look, tight fitment, kits etc, know what I mean?
thats mine as it sits presently pretty much
Saw a nicely done silver s2 33 at the gym the other day... Looks like they took inspiration from Billy's car. Nice stance and fitment, spoilerless, roof spoiler etc. I'll put a photo up when I get home from work. Only let down was I don't think they were decent jap wheels but they still looked alright ( I just prefer quality jap wheels on jap cars)
Had a massive dildo gear knob on it too lol
yeh i know it has the lenso d1rs its nice but from memory its NA and possibly auto ?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
