34R / Eastbear seats are ok for track work. They allow you to still have feeling in your ass once you arrive at the track as well.
32/33 are almost useless as the shoulder wings are not large enough.
And get some KU31's they own in the wet from all reports. They cost more than KU36 for a reason....
How is your car now Hamish that is sounds like s Saab wagon?
+1 for no shoulder support but they fit my bum great :) its also handy not having sides when you have to deal with a ballin kid in the back
+1 for KU31s got a full set for the misssus car for 540$ and they are great in all conditions and they ride is really nice and comfy to...will be better when I get my koni yellows from the states, 600$ for a full set = win
dont do it!! I have em on my car pretty good in the dry shocking in the wet!!
i would consider another tire since its winter and aint gana stop raining
jus sayin have a read on them :thumbsup:
that's just a load of shit.... ku36's are nowhere near as bad in the wet as people say.
for some reason people buy 36's and expect the performance of an RE55, it's NEVER going to happen
they are NOT a semi slick tyre, they are just a street tyre. they perform fine in the wet for what they cost/are. and yes I have used them on many occasions
i should know in less than a week :)
volvo motor FTW
volvo motor FTW
I dunno about you guys, but I can't buy or consider buying performance/sports cars I've beaten in run ins with my near standard R33. They just seem to lose their appeal after that. MPS, XR5 Turbo, Golf GTi, Cooper S, list goes on. Makes me think, why bother buying one of these when such an old car will just do away with it. Not saying the new cars have to get faster and faster, but they better have something special to offer and above a 15 year old Skyline that's all. Aesthetics and fuel economy maybe? A better feel? Not performance though...
there all phag ass cars anyway so why would you.
personally i like luxury over performance for daily duties
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
