You really think so? I found my 595's to be great. I was never lost for traction when I didn't want to be and they gave me some great launches on the skidpan. Just need to see the test of time now, but for 167 a corner, great value even if they only last 20,000km.
  • Replies 149
Its a matter of trying them and seeing how much better they are.
Sure for the money 595s are great, but if you want ultimate traction in a street tyre theres plenty of other options not too far from 595s pricewise.
I've had a second hand set of Conti SportsContact2s on the fronts for DECA and I was very happy with the way they performed.
If they were that good second hand, i'd like to see how they'd handle like when new.
I had the least understeer with these tires this DECA then any previous DECA i ran with different tires.
I'm running the same KU36's on the s14 as Rus and a big big fan of them.
def better than the 595 SS and the older RS.
that said I will be moving to the newer 595 rs-r when this set gone from those I spoke to def the tyres to run.
M
Me too, I ran 595's at the recent DECA and thought they were good for traction and with cornering.
What pressures are you running in yours?
Not sure what pressure, I haven't checked them since I had the tyres fitted to the wheels (couple weeks ago). Probably about time I gave them a pump :(
Admittedly I haven't tried the others you suggested but I've judged these ones against high end street tyres ($250+) that I've tested in the past and they came up pretty well IMO. At the same time my car is only producing 165rwkw so when I launch on boost I don't need a huge deal of grip to get moving.
Awesome Day!
So good to cut loose off public roads.
anyone know where we can find the footage from the legendary dude that was sticking the camera on the side of the cars?
also people having problems watching this:
'I have put up some in-car videos: http://www.youtube.com/user/tekjim#p/u'
OK Ladies!
Results are HERE
Great work from Russman taking out the win overall!
Also notable mentions for the little Lancer and MX5 getting right up there against the "big boys" :blink:
Other than that good work by all.
I Had a great day even though it was bloody hot standing out there on the long wang.
I will say though, its very interesting to see the difference between the fast and the slower times in the way people are comming into those stop gates.
I was on the long wang but I imagine that it goes for all the other gates during the day.
On that long wang finish, some of you guys could have knocked off sometimes up to 5 seconds I reckon if you just attacked the finish gate a little harder!!
In most cases that would have moved you up from mid-low field right up within in a couple of seconds or so of the front runners.
Somthing to keep in mind for next time :(
Also thanks to Tim, Shane, Mark & Russ for rides during the battles!!
Enjoy!
Looks like another great weekend. Shame Icouldn't be there. How was the after hours shenadigans?
I'll have to get the car down for at least 1 this year. Frysie, I hold you personally responsible if I don't get down there!
go Russman! and also well done to the Clive in the Lancer for taking out the highly contested "NA challenge"..
some of my times were slower in my second run compared to my first run... usually it's the other way round for me, something to improve on for next time I guess.
p.s. for Pat: Z32>R32, 3.0L>2.0L and NA is best :(
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
