I'm hoping pump gas cause here we dont have 98RON. Dunno what the knock is gonna be on our horrible gas, might have to go water/meth inj. for a save tune.
Hey Girorostar, yeah most of the fuel you get on the islands is fairly poor ( comparitable to a mix of 91 and cheap ethanol)... I spend quite a lot of time in the carib/lower carib/trinidad etc on private superyachts.
I'd suggest buying 20lt drums of toluene and add a 7:1 mix of gasoline:toluene. Your biggest problem will be that the fuel you get where you are isn't of a constant grade and is usually full of water!
If you tune your car on a 'good' batch of fuel then fill up will a different/poor batch of fuel and drive the car hard you may very well damage the engine quite quickly.
Water will damage your fuel system and will also allow sludge/bactiria to grow in your fuel system (it'll gunk it up pretty quick). The biologicals actually live in the water but feed on hydrocarbons (your fuel) then 'poop' out more water and gas/sulfates etc.
I've helped a few guys with they're imports on the islands, this is what I suggest:
Toluene
Good knock sensor and indicator (eg Power FC)
Good knock correction mapping
Very conservative tune
Single point methanol injection... (seperate tank, pump, injector and controller) Not WMI.
We set up a single point meth injector on a s13 in Sint Maartin... worked quite well!
Good luck
Justin
Toluene
Good luck
Justin
Thanks for the advice Justin, yea the biggest issues a lot of RB motors has on this island is fuel, they dont like it! I will start doing some research on this on how to set it up on my car. Hope everything will go right and i dont blow the engine.
A friend of mine with a r33 gtr made 315rwkw on pump gas here but he has a HKS built motor and another friend of mine with a stock motor r33 gtst made 270rwkw on a very conservative tune cause he had a lot of knock on higher power had to lower the boost. He's still searching for a way to drop down the knock levels, I will tell him about this and see what he thinks.
  • 4 weeks later...
i will try the 5857 AR:82 on my RB26 !!! after i saw the result on a 1JZ from the state .
what do you guys think ?
If you plan to run E85 and 35psi I think you will be VERY happy.
I think you'll find that's about on the money... They're a great turbo if you'r running BIG boost numbers. Don't expect tooo much from 20psi.
Cheers
Justin
  • 1 month later...
  • 1 month later...
so what did the powertune r34 gtr with the 7175 billet on it make powerwise? the powercruise youtube vid is impressive to say the least....
About 0.0197hp/$1 at the fly.
Find the turbos suggested output and do the math, then consider that as a rough minimum.
Your chasing the wrong product, Honda has the power of dreams!
After the last dyno run, I've changed a few things- most importantly the exhaust. Turns out the center muffler has partially collapsed causing higher backpressure in that section of the exhaust. I'm not shure how that will change the power output, however it feels more responsive now.... either way I was allways changing setups to a top mount TD06 and there's no point re-tuning untill I get the new turbo on.
If anyone is interested I have my 5557 for sale at the moment. $1400 with 46mm wastegate and professionally made stock manifold adapter.
http://www.skylinesaustralia.com/forums/topic/361517-billet-turbo-hks-manifold-and-a-heap-more-good-gear/page__gopid__5772382#entry5772382
Cheers
Justin
  • 2 months later...
  • 2 months later...
So..... anyone got anymore results with these turbos?
PJ??? anyone?
also wat was the rear housing size on the precision billet 7175 used on the white r34 gtr
i want to go a 6765 divided for street and the exact 7175 used on the powertune 34 for show, race n dyno
Here's a suitably ridiculous result from an EVO in the states running a new Precision PT6766 (.82a/r hot side) at just over 40psi on E85:
Mustang Dynos read in the territory of Dyno Dynamics, they are not generous dynos at all - to put down 850awhp/634awkw this is a ridiculous piece of machinery. Imagine one on an E85 slurping RB30? :D
im ordering 1 monday...
built tomei 2.8, 288 jun cams, 2000cc id injectors... powertune twin 044 in tank setup...
wil b interesting, hope to have running by xmas or just afta...
do u think ported "hp" cover would make much difference over the non ported "h" cover?
cheers
cheers
On a big capacity good spooling engine you'll need the ported front cover to avoid surge but Rb's are known to spool slowly so you should ok without it...
bigmikespec, just want some advice from an expert.. wat are the pros n con of having and not having the surge cover for "my" application on this turbo?
i want to run about 25-30 psi on the street on e85 and keep winding it up for race til it tapers off the power/boost curve...
cheers
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
    • Some more close up pics now that I’m back to working on the car, the loop pile is nice but again haven’t compared it to the other types in person, it’s hard to tell from the pics on the website. View of the hemming on the edges too, it comes in 2 pieces - front and back, honestly very happy with it for anyone on the fence.  Also attached my previous pics from further up as it didn’t let me post them directly before. (Nothing worse than photo bucket pics that aren’t hosted anymore years later)
