Yeah Twin scroll. It feels fairly towy atm with it just running off the gate at 14psi. Will be very interesting to see how it compares with the old HKS T04Z. As for the tune just have to wait & see when mark has the time to come down. Hopefully within the next few weeks.
Pulled 604Hp at all 4 with T04Z on 24 psi So yeah Cant wait to see, Noticed the precision turbo is very Quiet which is a good thing I reckons.
Quiete??? Ours spool like a jet fighter. Love it
Is the PT6766 any laggier than the T04Z? Surprised its not very rowdy, the GT3794R-HTAs (basically the PT6766s closest match) seem to scream.
Please post results up when its done, will be very interesting :)
Yeah ya right it has that jet sound about it. But at 14 psi isnt much for that turbo at 35psi well me thinks it might suck a jet out of the sky or kill afew miner birds. lol. Should sound awesome
Will post up results once tuned Looking foward to it.
what happened?
Nothing major man, just a few little dramas like collapsed coilovers, BOV blown clean off the pipe and a gut full of stale E85 which makes it no go at the moment..... Other than that its awesome!
Did u get ur ethanol sensor working again? We have already had 1 die. Lucky i had a spare fir my car. Warranty phone call will be made today for a replacement
Will let you know once its got decent fuel etc again.... should be OK but i did get an E100 reading and also an Esen a few times....
Sounds rough, howd you manage to blow the bov off the pipe? Do you mean the return pipe blew off, or that it actually blew the welded flange for the bov on your cooler piping?
If its the latter, wow...
Stale e85???
Yep, my fault man! Storage issue!
Off the pipe as the idiot up here that did my pipiing didnt put a bead for the clamp to grab on and also overtightened the clamp, ive probably had a slight leak the whole time... Temporary fix -
:laugh:
You've had a eth content sensor fail? What type, and what were the symptoms?
I dont think mine is failing, however it did do the same thing as Kurtis's so ill be keeping an eye on it.... Got an E100 reading randomly and also Esen (i think thats what it said anyway)....
watch 600hp turn into 600kw like Lith said, LOL.
it is tuned for what your doing atm yeah? not boosting it on the T04Z tune are you?
when you say toey do you mean its pretty lively under the foot? responsive for the amount of power it will make?
Yeah have driven it home off the gate have boosted it on to4z tune Mark said it would be okay, Until we do the full tune. Felt lively with just 1bar under foot quick spirt in second had good pull. But its in the shed awaiting for the tune day, 600kw Ya reckons guys I wont know what hit me.
Hope
Just hope the rest of your setup is up to the task LOL!
Hope so should be okay have ppg dog set in gearbox. 2000cc injectors to go in. Only thing that is a bit worrying is the spark & the twin walbros in the tank been fine thus far. But it pays to have vital gauges in the cockpit fuel pressure & oil pressure.
I dont understand why some turbo cars eg R34GTT came with the stupid useless battery voltage gauge and the boost gauge which isnt accurate( and generally replaced when modded anyway). The most important gauge, the AFR gauge could have taken their place.
There's a lot of things you don't seem to understand.
These weren't intended as fkn race cars dude. Why would your average driver need an AFR gauge? Battery voltage is much more useful. As for the boost gauge being inaccurate, they are almost 15 years old now, of course they are inaccurate. AFR is far from the most important gauge, in fact I'd say they are completely unnecessary unless you are planning on doing your own tuning or tracking the car.
Edited by Hanaldo
And how is the battery voltage useful, explain? As most cars, like the vast majority dont come with one.
It's not overly useful, it's just more useful than an AFR gauge to most people.
Gauges are really just about learning the 'norm' for your car. So if you're like me and you constantly watch your gauges, you know what is normal and what is not. If your alternator starts to die or your volt load changes, you'll notice it and possibly avoid getting stuck. Can also be useful for determining the load on your alternator, ie. watch how far it dips when you turn your headlights/radio/horn/etc. on. Or watching to make sure your car is charging at the correct voltage, not over or under charging.
All of this generally means a hell of a lot more and is more subject to change than the air:fuel ratio of a car. The way Nissan intended the car to function, the AFR should never really change a lot, so it's useless to monitor it.
You will love it! Keep some undies in the glove box ;)
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
