Lets put it this way; you'll be having a new bottom end quite soon. The engine for testing is waiting on one part before assembly, and that part is being picked up at the end of this week and sent...
Oh getting excited!
My 6262 was on full 21-22psi by 4000rpm and had strong low end urge. Was a 0.82 housing on a stock RB26 and ViPec better than my GT3582R with 0.82 ex housing
What sorta power did you make? Petrol or E85?
Really? Why did 5 if his customers just buy 5 precision turbo's but he tell u not too? Weird
Strange - him and his workmaate Mark have talked me IN to the 5558 now over the 3076R. Said spool and midrange response pre-22psi is so similar on the street, you'll hardly notice at all, but after 23-25psi the 5558 leaves the 3076R far behind. Got my gate yesterday and have sent out pricing requests to the US for the Precision CEA billet 5558 T3 / V-band and 0.63/0.82, surge slotted 3" cover.
I think mine and Kurtis's feel different and are pretty similar setups.... Maybe one day we will run em up on the same dyno and see what the rollers say
what kinda of power will these make on e85?
I feel sorry for you guys now..Ron is going to come in here and not make up his mind.
RON JUST BUY A FARKING TURBO STRAP IT ON AND BOOST!
You honestly are worse then a girl at picking things
Lol
Ron- precision have proven themselves already. Good choice
Hahahahaha!!! I am, dude! But yes its happening this week..
Edited by rondofj
Low mounting on stock mani for that shopping girly look, 0.63a/r as recommended by Jezzabelle n Jase, clicking on 'buy now' soon to shut myself up - these things come with the pretty anti surge slots that dont seem to work on the kandos..but gotta live with that.
This is NO good Ron................ NOAWWWWWWWWWWWWWWWWW :D
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
