Thanks very muchly. What's a new chra worth if worst comes to worst
That I'm not sure about, but the JB CHRA will have the longer life span if anything.
Nothing to worry about.
Wait what!
You changed your mind again?!
No, no.
Before my budget crisis I had a PT 5558 on order. Shit happened and I ended up selling my 6boobs etc and went factory low mount with the SS1PU.
Nothing has changed, motor is mostly assembled (turbo attached now). Just need a new sump pan (mines rooted), rear main seal and ancillary water hoses then I'm bolting it in. Have taken a few pretty photos so once I get closer to results time I will make a thread of some sort. I prefer to lay low when I can and preserve identity but I do want to share the SS1PU SR experience.
I know there have been some failures in the past, but im sure thats old news.
In general JB's have a longer lifespan than BB's and are overall not as delicate.
The main thing I dont like about the PT BBs is that they arent water cooled. IMHO BB's should always be water cooled, too delicate to not.
water cooling is to take heat away from the turbo, which is oil lubricated and cooled also. remembering the turbo gets hundred of degrees going through the back side which is bolted directly to the CHRA you want to get as much heat away from the rotating assembly as possible.
Admittedly I do not follow the supra forums and PJ you already know I've never used a JB PT. Dunno whats to be proven here, but you guys win already.
I did plenty of reading myself when I was going to buy one and found plenty of posts like this saying 'get the BB' but hardly anyone actually having one fail in the past 3 years - I could be ignorant and not reading the right places so who knows. I'll just keep my mouth shut in future, no use trying to help people and share what you think you know when others are only going to shoot you down.
Yay ball bearing party, lets all dance and clap.
Theres been heaps of failures in last 3 yrs...people have been reporting them as being worse as far as i can see
The GFC may have forced there quality control to be not as good as it was...
people aren't shooting you down..no need for knicker nottage..lol, its just you said " you are sure its old news"...i mean
you can't be sure at all? i'd never ever ever buy one, now or in the last 10 yrs
cheers
darren
Isn't water cooling only for the cool down after engine shut down? If you have a turbo timer or let your car idle after a drive then I'm sure it'll be fine
after many discussions with my turbo guy, that was my understanding also...
Be interesting to see how these oil only Precisions last,, should be fine if shut down correctly..
I like the V-Band turbo/manifold idea too, should take care of any gasket issues. watching this thread with interest
Edited by tricstar
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
