Thanks very muchly. What's a new chra worth if worst comes to worst
That I'm not sure about, but the JB CHRA will have the longer life span if anything.
Nothing to worry about.
Wait what!
You changed your mind again?!
No, no.
Before my budget crisis I had a PT 5558 on order. Shit happened and I ended up selling my 6boobs etc and went factory low mount with the SS1PU.
Nothing has changed, motor is mostly assembled (turbo attached now). Just need a new sump pan (mines rooted), rear main seal and ancillary water hoses then I'm bolting it in. Have taken a few pretty photos so once I get closer to results time I will make a thread of some sort. I prefer to lay low when I can and preserve identity but I do want to share the SS1PU SR experience.
I know there have been some failures in the past, but im sure thats old news.
In general JB's have a longer lifespan than BB's and are overall not as delicate.
The main thing I dont like about the PT BBs is that they arent water cooled. IMHO BB's should always be water cooled, too delicate to not.
water cooling is to take heat away from the turbo, which is oil lubricated and cooled also. remembering the turbo gets hundred of degrees going through the back side which is bolted directly to the CHRA you want to get as much heat away from the rotating assembly as possible.
Admittedly I do not follow the supra forums and PJ you already know I've never used a JB PT. Dunno whats to be proven here, but you guys win already.
I did plenty of reading myself when I was going to buy one and found plenty of posts like this saying 'get the BB' but hardly anyone actually having one fail in the past 3 years - I could be ignorant and not reading the right places so who knows. I'll just keep my mouth shut in future, no use trying to help people and share what you think you know when others are only going to shoot you down.
Yay ball bearing party, lets all dance and clap.
Theres been heaps of failures in last 3 yrs...people have been reporting them as being worse as far as i can see
The GFC may have forced there quality control to be not as good as it was...
people aren't shooting you down..no need for knicker nottage..lol, its just you said " you are sure its old news"...i mean
you can't be sure at all? i'd never ever ever buy one, now or in the last 10 yrs
cheers
darren
Isn't water cooling only for the cool down after engine shut down? If you have a turbo timer or let your car idle after a drive then I'm sure it'll be fine
after many discussions with my turbo guy, that was my understanding also...
Be interesting to see how these oil only Precisions last,, should be fine if shut down correctly..
I like the V-Band turbo/manifold idea too, should take care of any gasket issues. watching this thread with interest
Edited by tricstar
    • Even with the piston at TDC there was room for it to drop, but I don't think it can drop fully into the cylinder, the problem you have is that you need something pushing against the valve to hold it up so you have enough room to put the new stem seal on and the spring etc.  I used compressed air only because putting rope in the cylinder seemed a bit risky to me, I know people have done it countless times before like this. Overall it's a pain in the ass job. Honestly you'd probably be better off taking the head off because the risk of dropping something in the engine and the finicky-ness of it all is very stressful. If you are going to attempt it though i 10000% recommend a 36050 valve spring/keeper tool. I had both the traditional lever type and after doing 1 cylinder it was absolute pain to get those valve keepers in place, even with 2 people. That 36050 is amazing, you do have to push hard to get them in place but it works perfectly almost every time. Back to my actual issue I think my engine is just tired and old and the rings have gone bad. The comp numbers (cold, no oil) were: Cyl 1 -129psi Cyl 2 - 133psi Cyl 3 - 138psi Cyl 4 - 137psi Cyl 5 - 157psi Cyl 6 - 142psi   Cylinder 5 and 6 having the most carbon on them.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
