Just confirmed my suspicision for the laggy-ness, inspected n tensioned my throttle cable to just about touch-tight responsiveness. Doesnt feel so laggy now anymore, got a lot of the crisp touch- responsiveness of my stock turbo back and smiles all round. Very nice street turbo the 5558, mines not so linear but gives an angry meaty kick at 4000ish which is what I always wanted. Still running pretty pussy boost 16-18psi so top end is left wanting..
Ohhh man ur really peer-pressuring me lolz..:( was thinking water injection, re-route part-cooler pipe, crank up boost as next mod... And clutch when the stocker shits itself haha. Have you seen my dyno-plot, and any comments? Laggy hey.. Well I only know the stocker's response thats why I keep saying its a bit of a lag-boat.
Ohhh man ur really peer-pressuring me lolz.. :( was thinking water injection, re-route part-cooler pipe, crank up boost as next mod... And clutch when the stocker shits itself haha. Have you seen my dyno-plot, and any comments? Laggy hey.. Well I only know the stocker's response thats why I keep saying its a bit of a lag-boat.
all of the stuff on your printout is just about identical to my gtx3076 with 0.82 when i had a tune on 98pulp.
Hey thanks man, if thats the case then I should be pretty happy that it matches a top of the range Garret..and yes it does wheelspin n skate second gear on 18 inch Bridgestone Potenzas. Third as well if I give it some stick. How much torque did you make, mine comes to 736Nm if that can be relied on. And Kasko ur right, it will never be like the stocker down low but its not far off either :)
Edited by rondofj
f**k rerouting intercooler pipe..waste of time and money , water injection will fix it, my mates vl i did, 28psi of boost, before intake mani was to
hot to touch, now with 450cc of water in its guts you can touch it fine...
Its one way to fix chinese intercooler problems(eg they make good power and flow well, but heatsoak really easy..lol)
cheers
darren
Edited by jet_r31
i was making 641nm, so looks like the two turbo's are similar on that boost, not sure about the housing differences though..
its a good result though, looks like 16psi, probably needs atleast 20psi to really unleash
Well the ching ching cooler is doin a good job because the outlet pipe up till a bit past the battery tray is nice n cool, BUT once you reach the rad/fan area it heats up pretty quick all the way to intake mani. So I know its not the cooler thats why I wanted to re-route and heat wrap that bit of top pipe away from rad/fan and cam covers
Edited by rondofj
Yours honestly isnt laggy Ron, its pretty decent. Full boost threshold is pre 4000 which is decent. Peak toque isnt far off. It didnt make the 300 you hoped for but then again its close enough.
The result is pretty decent as is :)
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
