So I have finally booked the GTR in to get the PT6262 fitted.
I will finally have my own results to post in here..
Not chasing a power figure, will be adding new Cams, Cam Gears, Fuel system & ECU
starting out on 20psi and see how it all goes.
Going in my 34 GTR
6 boost Manifold, 50mm Progate & 6262 with .84
Haltech PS2000 ECU & IQ3 Logger dash to replace the MFD
New fuel system & some cams, cam gears and a few other bits and pieces.
Will post up a before & after run, looking forward to having a bit more power.
Going in my 34 GTR
Capacity?
Comp ratio?
Cams?
Exhaust size?
Going in my 34 GTR
Why the PS2000 and not the Platinum Pro plug-in?
Found this from Jan 25th 2013.
Car is 2001 Audi A4 1.8T
New 6262 CEA 620rhp @ 42psi (red)
Old  6262         520rhp @ 35psi (blue)
5857                420rhp @ 28psi (green)
Err, no? The different colours are hp, torque and boost, it's just a new 6262 versus and old 5857 in that comparison.
Capacity?
Comp ratio?
Cams?
Exhaust size?
Capacity: 2.6L
Comp ratio: Standard
Cams: HKS step 1's 272 8.7 lift (I think)
Exhaust: 4" dump into custom 3.5" exhaust with no mufflers
Will be tuned on E85 from the drum, the car is not my daily anymore and for $2,50/L I don't have to worry about watching the fuel prices jump up and down.
Because I'm not sticking with RB26 and don't wanna upgrade ECU's again.
Will utilize some of the additional channels from the PS2000 in the future.
A couple of people have also asked why the Logger IQ3, it's for same reason. buying now to setup so I don't have to replace in the future.
My aim is just to have a bit more poke when I press the accelerator down, I'm not chasing a power figure nor am I looking for a world record.
My r34 gtr came back from Micks Motorsport making 501AWKW 671AWHP on 28 psi on united e85 with a precision 6766 bb and on bp 98 it made 370AWKW 495AWHP 20 psi
the engine is currently a Nitto 2.7 stroker ,ported head a set of 270 deg cams, Precision 6766 and a Turbosmart hyper gate we will push for more soon, will put a graph up when I go to the workshop the motor was built buy Dahtone Racing
  • Like 1
im a bit surprised actually I thought this car was a pretty serious piece of top dollar machinery already. any reason you decided on the precision?
Hmm
Nah, my car is factory stock still. Only mod is the Fat Pipes exhaust.
I went precision to be different, turns out plenty of others have gone down the same road since this thread is 87 pages now.
Got a roller bearing 6262 to go on a mates 25/30 and it doesn't seem to spin as freely by hand as the GT35's I've had in the past. It actually hardly spins at all when idling. Is this normal or is there an issue somewhere
i have only ever seen this on BIG turbos as the air is passing past the turbo but not enough to spin it. Was on a 2J. I am 100% certain this isnt the issue here tho.
That's strange, can you show us a video?
JEM tuned a 33 GTR the other week.
RB26+6466+E85+35psi=604awkw.
So it was a 6466!? I saw the pic and figured it might have been a 6466 or 6766 but I got no response when I asked - I *love* 6466, they are clearly an awesome turbo. Any word on how it spools on the RB26? Should beg JEM for a dyno plot post, it would be very very interesting
:dry:
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
