On 01/03/2018 at 12:20 PM, SimonR32 said:
Should be interesting on weekend at Racewars, have 1000m run and I'm guessing I'll pick up a lot of speed from the sequential box. Best guess is around the 295km/hr region
Only got to 291km/hr but with the 30-40km/hr headwind I'm going to say I probably would have gone over the 295 that I expected. Got a very fast ET as well considering it was on AD08R street tyres on an unprepped airport runway.
Fastest pass here being a 18.106 @ 290.8km/hr with a half mile of 15.672 @ 180mph. The quarter mile was logged via GPS at a 10.2 @ 144.1mph
Edited by SimonR32
  • Like 2
Was not dissapointed with the stock block warriors! How your car consistently beats all of the big hp pretty looking ozzy park workshop builds is beyond me haha, those quarter figures would surely improve on a preped track yes?
  • Like 1
Would expect radials and motorplex to be a bit faster but who knows... I may get off my ass one day but need at least 18s to clear brakes
Why would it shock you mate? you pretty much summed up most workshop cars in your reply. They supposedly punch out big hp on a dyno but the track is a different story.... online warriors love dyno figures lol
  • Like 3
What size oil drain do you guys use?
Precision say minimum -10 which was supplied with the kit i got but after looking at the drain size at the base of the turbo it seems too small.
I didnt measure the factory turbo drain but from memory (which is terrible) it would be closer to -12.
Is this a case of bigger is better or will -10 be fine.
20180313_133413_resized_1.jpg.b067d59f8183c41550ec4abf2e9768af.jpg20180313_133823_resized(1).jpg.077e37861967d8349e37faa3fa342514.jpg
2 hours ago, burn4005 said:
i wouldn't worry about the drain on a precision, most of the oil goes out through the shaft seals.
So I run one, know several others that run them for years with no issues. Every time I see issues with seals it always appears to be install error
5 minutes ago, SiR_RB said:
Bigger drain the better on precision’s
and no sharp bends or kinks
I can run -12 drain flange on the turbo then use a -12 braid hose with a 45 degree fitting on the top end with a 90 degree on the bottom going in to the block just in front of the engine mount. Hose should be almost straight with only a slight bend. Might might have another look to see if i can use a 45 bend in the bottom of hose too but not sure if ill have clearance.
3 minutes ago, azzada1 said:
I also use an earls inline oil filter for the feed.. and be careful you dont accidentally turn the oil restrictor when tightening the oil feed line
Ok cheers thanks guys ill keep an eye on that, i think the kit came with -4 feed and turbosmart filter
Alot of people dont run the filter and dont run into any other issues either, But lets not pretend precision hasn't had its fair share of complaints and quality control issues.. I fit the filter for my own piece of mind and ended up having issues with the first motor and filter saved turbo.. my drain doesnt have any fittings just the push lock -12 i think it was and a nice curve to the block with heat sleave over it to make it last..
Edited by azzada1
i guess it probably helps that i don't leave the oil in the car for much more than 1000klms as the car doesnt get driven a lot. Its extreme, but when it sits for 6 months at a time and runs E85 we prefer to just swap out the oil and oil filter.
NEO25 - its been a while since i worked on a Skyline but is there any way you can run the front oil drain from an RB26 on your engine? it would make the drain very easy to make up then
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
