On 11/07/2022 at 12:13 PM, R377 said:
Thanks Lith, i haven't been on here for a few years now.
Always looking at street sensible (budget) RB25s.
From memory the 5858 sounded familar and also the 6262.  Quite a few yanks had some good results on their Evo / WRX.
Just looking at the Precision website, what are the new "gun" turbos ?
GEN2 PT5558 – 650hp
GEN2 PT5862 – 700hp
GEN2 PT6062 – 750hp
All good.
I'm not super super familiar with those tbh, I'm not going to bring up other turbos in a thread about Precisions but my opinion is that the Precision turbos really start starting to come into their own from the 64mm+ sizes - usually when you're looking at 75lb/min or less flowing turbos the aim is typically something that is geared towards being more snappy underfoot and the Precisions aren't necessarily famous for their transient response, at least compared to newer releases some other brands.
I do know those 3 have been out for a few years now already, and I have at least heard the 6062 is a solid performer in it's own right - makes good power for a 60mm turbo and not particularly laggy.  Suggesting that I feel there are better options in no means I think they're nuggets :)
  • Like 2
  • 8 months later...
anyone found any 6062 results? having a poke around and they dont seem to exist from reliable resources in Australia.
going to scale down from 6466 to 6062, also dropping cam size to pick up more downlow for rallysprint but just trying to make sure we are making the right move.
  • 5 months later...
Thought I'd bump this thread as Precision have been superceding their Gen2 units with the  "NextGen" range and the updated 6266 and 6466 have just been released, rated at 925 (more than the Gen2 6466) and 1000hp respectively so decent improvements and probably most relevant to people who would be reading this.
The NextGen 6670 has also been released, kinda like a 6870 flow (quoted at 1100hp) but sitting between the 6466 and 6870 size wise.
  • Like 2
I have been keeping up to date with their releases. The one that still doesn’t make sense to me is the new 7275 being capable of making 1380hp especially considering the 7475 that replaced the old 7675 is only able to make 1350hp.
These are precisions claims of corse and no one has actually tried any of them or if they have, haven’t show the results
44 minutes ago, Lithium said:
Fairly sure I've already seen a bonkers NextGen 7275 result, trying to think of where.  Could just be another Apex turbo result as those things are just mental
Be interesting to see gen2 vs next gen 7275 on the same car and a couple of the sportsman’s against it as well
Precision presented their new next gen 6466 yesterday. It's now rated to 1000hp vs the gen 2's 900hp rating. It's now available with either the S or HP cover. They mention that the cover has flow enhancements and I'm wondering if they will release the enhanced HP cover for the gen2's.
Edited by TurboTapin
  • 3 weeks later...
Is this based of the Mean Street Class Legal 6470 series turbos? If so, as much as i hate precisions due to the failures ive had, they will be a bonkers street turbo for the 3 litre guys if the same housing options exist.
If you hate Precisions but like some of the "insane power vs turbo size" things maybe worth having a nosy at ApexTurbo, be super interesting to see something like one of their 64mm or so type units on an RB30.    They seem to be getting results that seem impossible, even when you consider the latest Precision offerings...  most significant Evo/Honda turbo records have already been picked up by things running ApexTurbos and one of the Honda guys "downgraded" from a bigger Precision turbo to a 62mm Apex to try and make it easier to get off the line and ended up making significantly more power at the same time, like they cracked 1000whp which is mad even on a US dyno without nitrous etc.
On 15/10/2023 at 8:40 AM, Komdotkom said:
Jesus the Apex Turbo website is terrible, I couldn't buy something with so little detail.
yeah, went looking for scientific purposes, and discovered that you need a degree in banging your nephson's sister to navigate. Pricey too the buggers
  • Haha 1
I'm all for new products and manufacturers but they can't seriously expect to sell stuff with that type of information. Perhaps they sell through workshops who can demo the product on other cars.
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
    • Just like in being 14mm too small (296mm) makes it not fit, being 14mm too big (324mm) it also won't fit. You want to find the correct rotor.
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
