Hi Guys,
Well in the next few months i am hopefully going to be the owner of an R32 GTSt after an extended hiatus from the Skyline scene.
What i will be wanting to do with it, is eventually do a V8 conversion, now i understand that getting this approved through the RTA may prove difficult (even impossible) hence why i am wanting to research teh topic well before i go down that path.
Also, for anyone that has done this type of conversion, what's the best motor? I'd be looking at a Holden motor so would it be LS1/2/3? L98? I could also potentially have access to a "cheap" crate motor from the states, but not sure of what is available there, and would at this stage prefer to keep it local.
I know a few guys on here have done it, but i am under the impression they have only been used as track cars, nothing for street yet?
Cheers
Nick
https://www.sau.com.au/forums/topic/318419-v8-conversion-for-r32-gtst/
  • Replies 40
Posted Images
Hi Guys,
Cheers
Nick
Good luck with it Nick, it would surprise allot of enthusiasts when you take off from traffic lights and it grumbles like a V8
Have you read all the threads on this available through search? E.g.
http://www.skylinesaustralia.com/forums/Ls...on-t207355.html
http://www.skylinesaustralia.com/forums/R3...on-t187852.html
"LS1" and "LS2" should give lots of results.
I have followed Bezerks thread yes. And will continue to do so.
As for that other thread..starts off ok but then turns into a "Could an RB do Bathurst" thread...
Why not keep the engine "in-house", ie a Nissan engine - VH41 or VH45, far superior to the horrible lump of US cast iron.
Never really considered it to be honest. I'm fairly keen on doing an LS* conversion as i'm familiar with the motors and like the way they perform
I'd like to see someone get 300+Rwkws from an aspirated Nissan V8.
the Lsx engines are by far more compact than the VH engines as well.
We're presently in the process of dropping a VH41 from a Cima into an R32 race car.
We'll be using twin turbos from an R32 GT-R to give it a bit of extra oomph.
So far the issues we've run into are the firewall and gearbox adaptor. The firewall is going to need a little massaging and the adaptor is going to have to be fabricated to handle a 25DET box, nothing that won't be achievable.
The turbos will end up facing high and forward and we'll need cutouts on the bonnet to make them fit, but we'll have about 2cm on either side for strut tower clearance.
I think an NA version is possible for a road car but the LS is a better option for you as there are quite a few threads available on the builds.
Good luck with the project.
That would be because they are still using pushrods to activate the camshafts, rather than multi-valves and twin OH camshafts.
It's about time GM brought their technology into the latter part of the 20th century, before they even consider the 21st century.
LS engines have excellent engine weight/power ratio and as mentioned above engine size/power ratio. There're even lighter than all the RB engines and have much more power potential.
Pretty good for old ass tech. IIRC the low-tech LS3 sh!ts all over the the DOHC hi-tech BOSS in the FORD.
The number of camshafts doesn't determine the quality of an engine.
Hi Guys,
Cheers
Nick
If you can afford it get the LS7...427 cubic inches will fit anywhere a LS1 will fit ,around 500 neddies ...boooyah!!!!
No. But they've been supercharged to make that much, and relativly cheaply at that. Yes, there was a R33gts-t on here that had the VH45 conversion done, in QLD from what i remember. He ended up running a superharger on it, running methanol fuel, and some other fancy jazz. from what i remember it was in the low 10's at willowbank.
And yes, i deliver. spent a while going through my SAU history, but found the 20 page thread about it
linkie
enjoy.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
    • There is a warning that "this thread is super old" but they ignore that anyway...
    • With 10% Ethanol, we're talking 2-3% fuel consumption difference. The emissions reductions and octane boost in my opinion far outweigh this almost non existent loss.    My tanks sitting at 80%. Luckily that should go down fast as I'm on vacation again for the next two weeks.
