Hey guys, if it helps, I've fitted BC's to a bunch of cars at work now. I've got customers in Soarers, Skylines, Silvias and Subarus that I've fitted BC's to and all are doing very well. All customers are happy with the BC's, great product.
I'll be fitting them to my own Skyline in the not too distant future also.
Anyone interested in buying some Tein type HA jap spec coilovers out of my R33?
  • 2 months later...
Are these BC's Kidney Bashers as the Jap ones in my GTR now are killing me on every bump and the Left rear has a Bad Bang in it so they are Fooked.
Thinking of getting a set of these, mainly do Around Town driving and a bit of Highway on occasions... Are they easy to live with in normal conditions???
Cheers Dave
No issues with mine, have been running them in my stagea daily for 9 months.
I have fairly soft springs fitted, almost stock rates, but the dampening is set firm. They feel great on the road, well worth the money.
As with any coilover it depends on what spring rate you get. You probably want 4fr/3rr or 6fr/4rr for a decent ride.
Has anyone used these coilovers on the track? I am thinking of getting these for track days so I am interested to see what peoples thoughts are for these proposes.
I got a set of the BC ER's (external reservoir) made up for my R32 GTR that see's the track regularly. The standard rates they come with are 12kg front and 10kg rear which I think is way too hard. After liaising with Just Jap, i got the factory to produce a set with 8kg front and 6kg rear. They also revalved them for these spring rates and extended the lengths to ensure they would run at the heights i wanted.
I couldnt be happier with them. On the road i have compression and rebound set to full soft and on the track i have found that about the midpoint on both compression and rebound gives me the best feel. Coupled with the whiteline swaybars front and rear, the car is very neutral now whereas it used to be very understeer dominant. Ive cut my times down at lakeside substantially with these coilovers (and with the swaybars).
I couldnt be more happy with the service from Darron at Just Jap either. I was really impressed with the running around he did for me and the quick response time. I fully recommend these to anyone who are after a good track coilover without compromising too much on the street.
Cool looks like they hold up really well. I've been doing some research on them and there is a lot of good reviews through the other forums. Did it cost more to change the spring rates? If you don't mind how much did it all cost with swaybars as well? I am looking at doing the same thing if I go ahead and buy the BC's. PM me if you like. Cheers
The custom spring rates and setup were the same price which I thought was pretty amazing. There was a lot of extra effort put in to get them made up and at no extra charge to me! I got the swaybars through a seller on here or nissansilvia i think, they are Whiteline adjustable products and were around 210 each from memory.
This is what I was after, My Jap Ohlins that came with the car when I got it are terrible.... Lose my breath on some bumps!
Just ordered with JJ so we will see soon!!!!
Go for it, i went from Tein HAs that were in need of a bit of a rebuild and left my kidney on the side of the road to BC BR series and WOW!! so much nicer to drive my GTR as a daily now
Is it really worth going the ext resovoir BC's or is that just overkill for a daily/occasioanl track use?
If its mainly a streeter, just go the BR series mate. The ER's are great, but are more track oriented (harder). If i was choosing some for a daily, i would be going possibly the BR's with 6kg front, 4kg rear as a max spring rate combo
I went for the 8kg Front and 6kg Rear as per the site and it seem good for the short drive I did today after install.
Compared to what I had in there they are like silk..LOL
Just need to set my heights back to where they were and play with the dampening a little bit.
Edited by Turbo Dave
see i was thinking the same going BR's
iv currently got bilstien's on my gtr, and my rear left knocks like a motherf*ker, but bilstiens are an alright brand, so im thinking of jus overhauling them at pedders or somthing.
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
