  • 4 weeks later...
Just wondering how much lower than stock the car sits on the BC BR's when adjusted to maximum height. I need new suspension but am having trouble finding stock replacements. BC seems to be a good option for replacements and will give me the option of going a bit lower in the future if needed?
Also, just on a whim, anyone have some 260rs/stagea rs4s stock suspension in good condition laying around, my drivers side has sagged massively :/
You would be able to run stock height if you set them up like that Mike.
Have you tried this Scotty? Only asking as the rears on my R34 are close to max height and still 1-1.5" lower than stock. Different car of course.
hmm so might loose an inch or so possibly. With previous cars i've owned coil-overs, even at their max height setting have always been lower than stock.
I would love to go low, don't get me wrong, but some of the farm tracks to get to some of the more remote surf spots have some more 'off-road' type parts lol
  • 2 months later...
well im looking at jumping on the bandwagon for my 32R, going to BC BR with std 8/6 springs, car mostly used on street and looking to start doing bit more track
looks like JJR is the best choice in sydney
also looks like its available in two options, rubber mounts or pillowball mounts - anyone care to comment on noise level?
FYI - Had mine on a shock dyno after some track work as one had bled down after lack of use and they both tested perfectly... The rebound etc was all surprisingly good and close to being a perfectly matched set! So for a cheapie they seem to be a winner!
What spring rates do you run on the track and how do they feel on the street?
Do you have a graph from the dyno?
  • Like 1
Go with the rubber mount. Pillowball is effectively solid mounting so not going to provide much vibration insulation to the body. Also pillowball is just another part to wear out.
  • 2 months later...
I was at 8F 6R and they were quite nice to drive on... Smoother than my old Tein setup...
The front sprint rate is closer to 12kg on mine now...
Nope, its in my file at Road2Race, it was a pretty even graph and seemed to respond well to adjustment, surprising what a cheapie can do i guess!
  • Like 2
I take you went to a 12kg front as the 8kg was a bit sloppy on the track?
How did that change the ride on the street?
Correct...
Its pretty firm now, i rarely use the car on the street these days so not too concerned :)
  • Like 1
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
