Yeah same here. Tried it again and no good.
I can select Bluetooth as Source, and can see all the play/stop buttons etc on the menu, but it has some kind of Message Box saying 'Bluetooth <Japanese>'. I wonder if there is a setting in the Bluetooth menu.
I have an iPhone 3GS and it is paired and working to dial numbers.
  • 1 year later...
  • Replies 76
Posted Images
Hi guys..new here..well kind of anyway. Used to post back when i have my V35 (totalled blink.gif ). Anyway..now i'm back with the V36 (never learned my lesson biggrin.gif )..and since i can't remember my old user ID..had to register a new one..
Anyway, just bought myself a 2008 V36 coupe with Nav, music box, Side & Rear camera, leather seats. Not sure if i have the premium Bose or not (still no clue what model/package that is actually). I manage to work out quite a few of those Japanese menus/buttons (due to previous experience with my V35 cool.gif ) but i could not, for the life of me, get the bluetooth to work!!! :ermm: . I manage to get to the menu where there is "Bluetooth" in the menu but the "Bluetooth On" button is greyed out. There is only 3 selectable buttons there which is the Bluetoth password change (the one where you can enter numbers), Bluetooth info and a button which leads to a lists of Japanese menus.
Is my bluetooth on already? if not, how do i on it? Before anyone ask, i know i have bluetooth as there is the phone & voice commannd button on my steering wheel. HELP ME!!... :ermm:
PS: Oh yeah..i have a Sony Erricson Satio phone.
sorry to dig up an old thread, but how did you get bluetooth to turn on again? mine's greyed out as well and only have 3 options available.. i pressed something and then something else, and now the option to turn bluetooth on is no longer available...
  • 7 months later...
Hi guys.... not too sure if everyone has found a way to play music from your phone via bluetooth but I had a bit of a play with it yesterday. I initially got my phone connected and can make calls but had trouble getting the system to play music from my phone. After some trying, I found out that it's because the system is set up to play music from the car's japanese owner's phone. I think all you need to do is to go to your bluetooth setting and select the right handset. I tried this and noticed that there are 2 phones setup with the previous owner's phone selected. So all i did was to select my phone and then delete the previous owner's phone from the list and I can now play music from my phone.
  • 4 weeks later...
What phone you using there bud?
I have tried every phone anyone has in my house and none will work not even a crappy little Nokia C2 lol btw phones i tried are Iphone 3Gs, Iphone 4s, Smasung S2, HTC Velocity, HTC One (m7) and the Nokia and still no luck with the bluetooth streaming, the problem has to be software based as 3 yrs ago my 3Gs worked in my friends car...
  • 1 month later...
Once the phone is paired via the normal means (aka. the instructions in this thread) then you should simply need to hit either the DISK button on the main control panel or Source button on the steering wheel controls and it should cycle through to Bluetooth music. Normally is cycles through Music Box, CD etc but once the bluetooth is connected then it should come up as another option.
I've actually heard that bluetooth music was only introduced to the USDM models in 2010, so I really don't know why my 2008 JDM has it.
Mine has a nasty habit of randomly disconnecting though for some reason. Works 100% with just the phone but as soon as I try playing music, it will play for a random amount of time and then disconnect the bluetooth. Turning bluetooth off/on on the phone fixes it up straight away but its still makes it too painful to use. I am guessing that it has something to do with it being a 2008 bluetooth system and a 2011 phone.
Sudden thought......the above is with my old Galaxy S2 and I actually have a Galaxy S4 now. When I get home, i'll give it a try and see if it has the same problem.
Mine's a 2007 and I have Bluetooth music and I never had any issues with playing music or making phone calls. No cuts, disconnections, nothing. Tried with iPhone 4, 4s and 5 all good.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
