Congrats on the purchase.
for those wanting to know, the 2011 GTR is still a ways off but will have 15-30hp more, revised aero for more downforce, revised front bar, revised rear diffuser, tweaked suspension. There will be (in Japan at least) another trim level above Premium with many options available such as the ability to option interior colours (not just black or white) and even option on parts from the SpecV range. It will not be called the SpecM as previously thought it has not been given a name yet.
The SpecV goes away next year as it becomes obsolete with all the changes in the base GT-R, and it's possible that the base 2011 GT-R will gain the power upgrade by making the 2010 SpecV turbos standard across the range.
  • Replies 70
Posted Images
Don't you dare show my girlfriend that!  :D
No but I still wouldnt buy that. 1. cant drive that knowing it 'aint a f430
                                            2. Its over 10 years old
                                            3. service costs and parts and insurance!
But still...its a 'ferrari pal!'  haha
Well... I bought the car. I pick it up in about 3 weeks. Excited but also nervous.
Thanks again for your advice guys.
Ill post again when I pick it up Domino.
you will love it mate. basically any car that costs more than a corolla is a waste of money as a corolla gets you from a-b in safety and comfort affordably. but the thing is cars aren't about money. like I said anything above a corolla is basically an emotional choice. so whether is a $50K monaro or a $400K 911 Turbo we do it because whatever the car is hits a button in us somewhere. enjoy it. :D
it's your money mate, only you can justify the purchase
im in similar situation with the gf etc
as long as i have my houses under control, i dont mind making such a big purchase
go for it, and enjoy it, it's a great car.... constantly scraping the long front overhang excluded natch
im in melb, shoot me a pm when you pick the car up, my mates and i are always organising drives up to kinglake, toolangi, mt donna buang etc
hay mate do u know a guy named jordan, drives a bmw coupe?
you will love it mate. basically any car that costs more than a corolla is a waste of money as a corolla gets you from a-b in safety and comfort affordably. but the thing is cars aren't about money. like I said anything above a corolla is basically an emotional choice. so whether is a $50K monaro or a $400K 911 Turbo we do it because whatever the car is hits a button in us somewhere. enjoy it. :)
Awesome philosophy. I agree 100%
Agreed. But to answer the question...I'm a pharmacist.
Just picked up a white one last Monday. Now for the gruelling 2000k run in!
congratulations.
that run in period should be just about enough time to order and receive a COBB access port and midpipe if you get on and order one now. ;)
congratulations.
that run in period should be just about enough time to order and receive a COBB access port and midpipe if you get on and order one now. :)
Would love to get those things but to find an installer and tuner in victoria?  :)
Who can I trust with my 35 in Vic?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
