Talk about stealing one new thread thought you bastard,,,but I digress.
This little toy is way cool,,,this little puppy is a rivet gun and like a rivet gun can also rivet thread inserts and stud inserts as well and no it's not for loan unless you can roll my guards at the same time.
Cheers
Neil
nutsert/rivnut guns are getting more common now- from $80 to $220
one at my shop does 4,6,8,10 mm threads. i love it
Yea mate everyone should have one,,,it's got me out of trouble so many times. The bastard that started this thread knows only to well.
I have more cool tools but it's to bloody cold to go out now and take pics.
cheers
Neil.
I've used one of these and think they are are great. If anybody is interested in one pm me as I will be buying 2 soon and can get more. Yes I'm going to buy off ebay usa. They are made by Lisle part no 24610.
Cheers
Neil.
Cheers
Neil.
Just recently seen these lol Damn handy.
This little guy has helped me more than a few times now Mirror with LEDs on it so i can hold the mirror and a Ratchet,screw driver...what ever instead of having to hold a torch and the mirror
This baby has got me out of trouble lots of times. Think about the last time you couldn't undo that rear hub nut,,,front pulley bolt,,,diff pinion flange nut,,,ect,,,for me it easily removes my centre wheel nuts on the Radical when we have over-tightened them. Very sweet tool indeed. It now travels with me where ever I go racing.
Proudly supplied by Mark at "Medalist",,,he's also just happens to be one of the founding members of "Team Raceworx".
Thanks Marky.
Cheers
Neil.
Thanks Marky.
Cheers
Neil.
damn straight....my favourite cool tool
for anyone that has not seen one....it is a 64x geared socket driver.
So you turn the handle 64 times for a single turn of the socket....but at the same time it puts in 64x the force.
You can undo absolutely anything with this.....just think a bolt or nut done up to 640nm (like an overtightened centrelock wheel nut) only takes 10nm and some time to undo
  • Like 1
One I find handy quite regularly is my Narva LED torch (link: http://narva.com.au/products/browse/led-2, see item 71302).
It's super-bright (450 lumens for 4hrs), stays charged for ages if it's barely used, and even better that I got it for FREE!
Vice Grips: Great for undoing rounded nuts and bolts that someones buggered and holding hot exhaust parts, welding, oxy etc
Rubber Mallet: Awesome for beating crap out of something a hammer would normally destroy.
The Large Pry Bar: Very useful for prying things...separating engines from gearboxes, sliding out stubborn driveshafts, control arms etc
Thanks Marky.
Cheers
Neil.
What's one of those worth?
Cheers
Neil.
Let me know when and how much.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
