The mrs got some vids of turn 12/13 on to the main straight. If only every day was a track day.
Spoke to you at Sandown on the 13th of October definately have
a nice R32 GTR there , the GT3 Porsche could just not keep up with you .
G'day good chatting. Hopefully catch you at the track in your own 32 soon!
Cheers - yeah the second time I got out which the second vid is from it stopped raining and the track started to dry out towards the end, times started to drop. Still wasn't enough to get a feel for how it will behave in the corners and under heavy braking but I will get there.
Got my eye on a Winton test n tune on Friday...
Hit Winton today - much better than Sunday, satisfied now.
Car held together well, have a few suspension changes I would like to make to start firming it up as the suspension is still very much Tarmac Rally orientated.
R32 ABS is also really annoying on the track, time for it to be deleted.
Best for the day was a 1:35.5 which I am very happy with for its first real outing.
Everyone loves the flames... but not sure I will enjoy having to clean this off each outing though... bring on E85
Posted Image
very nice driving Paul.
So pleased to see it's going well on the track.
I'm taking mine to QR next weekend :)
Yeah ABS is a pain on the track.
You must be spitting some pretty nasty flames to BBQ that rest lol
Really nice car - identical to mine except for the stripped interior, awesome paint work, exceptional cage, and a million other things. Although you need to beat this flamage for true glory! :yes:
needs to be a bigger pic size man!
Ha the boys were explaining it in similar dimensions so I may be able come close.
I saw your 32 years back in ashburton. Jealousy levels were high - you still get it out to the track ?
not for a couple of years, my wife opened a can of whoop ass when our third baby was born so it was back to racing bikes with all the other MAMILs. I will never sell it though, its awesome as you would appreciate with your beast. I'll sneak a track day here and there I hope.
  • 5 months later...
Vid from Sandown yesterday, best for the day was a 1:20.4.
ABS unit still causing issues with the brakes, spongy / inconsistent so on a mission to remove that shortly along with some suspension tweaks to try clean up the braking. Also a bit of ducting for the radiator needed - yesterday after about 3 harder laps it would hit 100c water and 120c oil and sat there, add some ducting to force a bit of air through and I reckon it will be a very nice solution.
A bit of a brain fart at turn 11 deciding which gear to use and so still chasing that elusive Sandown teen, one more session would have been nice but a guy smashed his porsche. Should be an '18 in it with me driving after a few tweaks. Regardless this 32 is a whole lot of fun to drive :)
  • Like 1
    • Yes that’s what im trying to decide. Should I do stock gtt box or enclosed or open pod.
    • Also, I note OP is in Melbourne, which begs the question... are you aware of how illegal your car will be with a turbo, and intercooler and any sort of filter change? I don't know how you can get past the "2 intake mods" "rule" that seems to exist in Vic. Fully engineered might or might not get you there.
    • If you have a turbo... then the ducting holes I used to feed the pod are not available because your intercooler likely uses them. If you have an intercooler, your IAT's are going to be goverened by how good your intercooler setup is. I'm yet to really see anyone check IAT with a snorkel/boxed pod/proper CAI versus and unshielded pod. It would be interesting! But I suspect that the differences would not be so noticeable as if you were N/A as the intercooler is where the air is being cooled.. and out in front where the FMIC would be is a pretty good spot for it.. When I was turbo I pushed the stock GTT box as far as I could and made some pretty good power out of it, and noticed on the street I never made the same power/boost. Then I did a before and after run with a pod filter versus the box and picked up about 9PSI from the same boost duty cycle and about 50KW instantly. I never ran the stock box again, and recently removed it for my N/A setup. The box is restrictive to a degree - Even with the V8 setup I noticed I picked up power by removing the box completely, so punching holes from the bottom of it to get air from the passenger guard *helps* but the most effective one in my case was simply having the ducts, a pod, and no box around it. In my experience, *more* air was better than cold air. The air (with ducts) will be cooled off as you start moving, and especially if you start moving fast (a race track). It actually moves around quite a bit as you can see.
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
