Haha yeah, sick rolling photo. I must take a rolling photo now :P.
Reminds me I don't think I've posted a pic of mine in this thread...
So may as well, lols.
Sadly just an iphone pic.
Edited by kaitoukid
Thanks man! But sadly I'll be raising the fronts a tad when I get time, some scrubbing action going on depending on turn angle haha. Against the guard liner methinks. But hopefully don't have to raise too much. And still debating on whether I ceebs getting some spacers. Or put it all into evo fund :P.
your car would die on my driveway.
My car scraped on yours today and it's not even that low ya f**k.
His driveway is surprisingly evil... Left me single spinning and threw my A-LSD into error mode :(
my current car:
:fakenopic:
It sold? Congrats :) Cash Money!
Yeah it doesn't look any worse than my driveway, yet my KAAZ spat the dummy and nearly launched me into his fence. Pretty sure it gets you up on 2 wheels. Gonna take it front on next time - screw my front bar.
sounds evil :|
that said unexpected detours are the worst! was at an event sunday night, and when i got there (fashionably late, of course) i was told there was no more parking (entrance was nice and steep too, but at least it was smooth!). told to go park in (or next to) a church across and slightly up the road... so much scraping there... narrow entrance, crappy road... eurgh!
learn2diff noob
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
