Yeh, I am so busy the car isnt getting finished and very little is happening at the moment. I am not even getting to go hassle Marlin and down cans :( ....and I go to see about getting some titanium pins remvoed because they are causing me problems and now getting all sorts of probes and tests to explain my 150/110 blood pressure. Fark work I say !!!! :(
its called stress mate... sounds like you need some time off
I stress about what brake setup to leave on my car...my BP is farked because I have turned into a 110kg fat carnt. Can you say "gain of 20kgs in 18 months but in real terms its more because I have probably lost about 5-8kgs of muscle from training"
FARK WORK! Cant quit now because I am too proud to throw the towel in...but a serious re-think is coming at the end of this project. The retail therapy on car parts and snap trips away doing car stuff dont justify the pain any more. Would be a lot happier if i had a car in one piece ready to trash :)
no amount of money or pride is worth throwing away your health for
f**k pride, you know you do a good job and that's all that matters... sometimes you have to be prepared to walk away to really get what you want... nobody notices your suffering if the work is getting done, why should they?
110kg!... best mod you can do for your car is put down the cans and do some exercise! lol
I let myself go through my mid 20's... went from 75kg to 95 kg... its taken 3 years to get remotely back in shape and its farking hard work!
anyway enough of the self improvement lecture, back to cars :cheers:
lol, you are still a handsome, strapping young man in my eyes bris. that 110kg is mostly in your massive wanger and maybe your brains and muscle for the rest. If I was a hot young chick I'd be all over you like a rash. :)
now back to work slacker!!!
Word :)
yeah fatz knows what he's talking about. loosing weight is for poofs.
come on bris. are you old school irish? or new school faggoty irish?
tell me your fken old school irish mate....
tommy gavin would be rolling over in his alcohol soaked grave.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
