yes, definitely get some adjustable cam gears before the tune so they can be adjusted too when it's tuned.
as far as brand. envy imports in sydney make good ones. they use standard gears that they cut the centre out of and fit an adjustable piece. this is good as the outer parts is still factory (steel and strong). some alloy gears suffer from the teeth wearing but these wont. and with 5 fasteners they shouldn't slip either. apart from those I also like the tomei and trust gears. other workshops around also make their own using standard gears like envy does too, as long as they are made properly they are a good option.
Cheers Beer Baron just sent envy an email!
  • Replies 467
Well I managed to pick up some flag-r ohlins last night. Got them for 89500 yen + shipping. Just gotta organize 6k and 8k swift springs for them now. And Barron ur right the springs are cheap, just under 15000 yen a pair :)
600k coilovers for 89k? Whats wrong with them?
I agree with Marlin above most definitely regarding adjustable bushes.
I would also like to go back to diff centres, particularly if anyone has experience with Torsion diffs in the front like that offered by Quaife instead of a 1.0/1.5 way? Would it be a better option? I am not sure if they are rebuildable like a Nismo 1.0/1.5/2.0 which uses clutch type plates.
The Quaiffe diffs are fundamentally different to the friction plate types from Nismo etc.
They come with a lifetime guarantee.
See here.
http://www.quaife.co.uk/differentials
I'll proudly stand up here and say my car has only Fulcrum eccentric bushes in the front and rear upper arms and castor rods :)
That's legal for the rallies I do, and cheap! I'm also a tight arse :D
I'd rather spend the money on fuel and rubber to practice. I figure it's easier to teach me to drive it quicker than spend time and money on arms.
Kaido, my suggestion is do the minimum required to get it track reliable, and feel the car out, making changes only if you think there will be a tangiable improvement. I don't see much point in throwing a catalogue at it and endlessly chasing the right heights and settings.
Advised settings differ from everyone around the country. I've lost track of the PMs I've received asking for my basic settings, only to be told I'm blatantly wrong! Lol
My R 32 R had Whiteline eccentric bushes in it with a slightly lowered front ride height & Cusco castor rods. It destroyed the bushes at Wanneroo iwithin one days running. I would reckon a few other people have had that experience.
At the end of the day you need to address the upper link & mount so that it lasts & so that you get some front end grip.
In the absence of anyone making a decent front upper arm that can use bushes I made my own. Teamed with a Mismo link bracket (which is a stock with with different drill holes) it works fine.
Marlin is 100% right also. I have seen alot of people with flash cars that couldn't drive out of sight on a dark night. For anyone in WA who wants to learn they could do alot worse that the the WASCC Competition Driving school. For $200 bucks it is a good way to spend some money. There is one on the 1st November.
See here.
Yes I know they are much different. Would love to hear feedback of someone who has used one? Missed that bit about lifetime guarantee that is good to know!
http://www.quaife.co.uk/catalogue/products/qdf3l
P.O.A makes me nervous :)
No idea. Got my mate having a good look over them before they get sent here. Anyone know what those blue circles are?
Im thinking cut helper springs but then again it doesnt make sense to include them in a sale.
P.O.A makes me nervous :D
Well ask & you may be surprised. They are (from memory) more expensive than the Japanese stuff but not massively so. Also it probably depends on the exchange rate a bit too so it would be worth asking the question.
the two blue little circles by themselves are spring insulators. just pieces of rubber. the blue bits on the shocks between the main springs and the lower spring perch are helper springs. just there to keep the springs captive under droop.
the springs fitted to the shocks are swift. that bronze colour is the swift 'default' spring colour. do you know what rates they are? good score.
Cheers mate, spring rates in them now are 10k front and rear, they also come with a pair of those mines springs (pictured) but they are 9k rates. I'm gonna grab a new set of swift 8k fronts and 6k rears for them.
Just an update return home from my one week holiday to find my nice new arc filters had come :D also waiting on my hks piping kit, pfc dejtro and hks racing front pipe.
Need to find myself a good ebc dobt really like the bleed value, tossing up between the hks evc or blitz id3. The hks is more pricey but has a boost scarmble on a trigger function.
Finally got around to working on the gtr today.
Std Gtr brakes off! AP Racing Brakes on!
Now just need to replace the disc and pads on the rear and install the braided brake lines and the brakes are done! Will be using Shell Racing Fluid again
Ok Just some question regarding the brakes
Should i remove the stone guards? i have already remove a section as it was hitting the dog bone.
Will it help with cooling or is it not worth it?
And does anyone know if rear brake lines are the same for the gtr and the r33 gtst?
Take the stone guards off, and run ducting from the front of the car to the back of the brakes.
99% certain that the brake lines are the same between R32GTR and R33GTS.
Not sure if this is what you meant, but you're best bet is to duct air in behind the rotor hat to the vanes on the centre of the rotor. If you duct straight onto the rotor itself you are asking for warping and cracking.
There are a couple things to note:
1. At the rear the bushes for one of the suspension links is awfully close to the rotor. Have a good look and a think about it before you start grinding off stone guards.
2. The inner pads will run hotter than the outer pads - with or without stone guards removed. It is good practice to check to tapered pad wear on the inner pad as it is common even on callipers that have staggered piston sizes.
Blah, never had an issue in 10+ years of R32 stone gaurd off action :cool:
Well, neither have I but I took the precaution of taping up the upright & link with some heat reflective tape to make sure it kept cool. Mabe if the rotten thing weren't so fat we wouldn't have this problem. Ateast the backs don't get anywhere near as hot as the front, but the inside pads wear alot faster than the outers.
same here.....probably 10% faster wear on the inner
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
    • Some more close up pics now that I’m back to working on the car, the loop pile is nice but again haven’t compared it to the other types in person, it’s hard to tell from the pics on the website. View of the hemming on the edges too, it comes in 2 pieces - front and back, honestly very happy with it for anyone on the fence.  Also attached my previous pics from further up as it didn’t let me post them directly before. (Nothing worse than photo bucket pics that aren’t hosted anymore years later)
