  • 9 months later...
  • 4 weeks later...
  • 2 years later...
Hello everyone
HELP
 i am currently converting my r34 GT rb25de NEO to now become turbo charged....now i have a couple of questions for you guys that i hope you can help me with.
#1 Is it possible to use a complete stock r33 turbo intake? or a fredyy/greddy? ( I HAVE BOTH)
#2 Can it be done using stock NA/DE engine Harness?
Lastly i Have  a Turbo R34 GTT Ecu to run it all.
THANKS! ADVICE IS URGENTLY NEEDED
  • 5 months later...
On 2/2/2004 at 8:38 PM, 666DAN said:
So you want to get more bang for your buck and whack a turbo on your skyline….well the following are things I’ve found out on this ever talked about path.
First thing…get yourself an N/A Skyline, if you’re reading this then you too have made this fatal mistake :)
The second thing you should do is get yourself some sort of engine management…one that can adjust airflow maps and injection maps…to a lesser extent timing.
I used the GReddy e-manage as my car is auto and I didn’t have a choice in the matter, even if it had been manual I still think I would have got it, due to the ease of installation and programming.
Other options available are getting the factory ECU…but I’m not sure if it would work as it would not have all the signals coming in that the stock turbo engine would put out.
Next step get the essential engine parts…you WILL need the following.
Turbo (of course) preferably with water an oil lines
Exhaust manifold
Dump-pipe & Front pipe
Fuel Pump (GTS-t one or better, plenty of high-flowing cheap ones out there, walbro etc)
Injectors (stock GTS-t ones or better)
Intercooler and piping (stock or custom)
Alloy cross-pipe with BOV (once again custom jobby will suffice)
All of the above can be the factory items or replacement parts for the turbo model, not a bad idea in the case of the intercooler…as with your 10:1 compression keeping things from going boom is a good idea :mad:
I used a series 1 R33 turbo, ceramic exhaust wheel jobby…you don’t really need anything more substantial as you can’t go too far past 7psi and the ceramic turbo should last indefinitely at this boost.
Almost all of these items went straight into my R34 with only the exhaust requiring an extra section welded in to make it fit.
The oil & water lines were modified and extended with stainless steel braided hose. The water supply was taken from the heater lines…the oil feed had to be taken from near the filter and the return is via a tap into the block..
Standard, the waste gate on the turbo will open at around 5psi..to get 7psi you’ll require either a bleed valve…or the factory solenoid powered by a constant 12v and put inline with the actuator hose on the turbo.
So now you’ve got everything bolted to your engine you need to get a complete dyno tune, where your ignition will most likely be retarded by about 5 degrees just to keep things safe. Once completed you now got a very different car from when you began…it’s actually got some decent power :D
Of course none of this would have been possible without Robin at *perFOURmance Motorsports*
The final tune on my car is Thursday, so I’ll have dyno charts and pictures available on Friday.
Anyone wanting specifics PM for more details.
So let’s see who’s next!
Dan
Could you run this setup through an auto easy enough? I have a 20e c34 would that work or would you recommend converting to Manual?
  • 1 month later...
  • 2 months later...
After reading through this entire post, which is great, I am still unclear how lower the compression ratio on a S2 REB25DE (R33). Is it just down to the pistons? If I replace the pistons with DET ones and probably rods as well, do I have the same CR as a standard DET?
I realise that I will not have the oil squirters, but maybe ceramic coating the pistons will help.
I think I have seen the valve springs might be a bit softer too.
Please fill in the gaps, if you have first hand experience with these and KNOW the answers. With the prices of RB25DETs in NZ right now I am considering rebuilding my DE, which I know, to DET spec, as close as possible.
You don't lower the compression is the answer.
but yeah the head cc is the same so comp is down to the piston dome
  • Like 1
Rb25de from 25det main difference is CR,if you change pistons,you will have det,except no oil squiters,head is 100%same,rods also the same,did the same for my DE,but i put det pistobs with rb26 rods,cause they are stronger,i am pushing 500hp on my setup,with Tonei cams,N1 oil pump,and be sure to install crank collar if you will dismantle your engine.I pushed 350hp with 1bar boost with stock DE,untill 2nd cylinder ringland failed,so its up to you,if you go over that,you need upgrades
Very helpful. Thank you Rolandas.
Another question: Are you running without the squirters? You have not installed them yourself as other have? That is pretty impressive numbers.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
