They have their good-from-factory place just like Preludes, Calibras and the rest of the FWD sporty marque. It's when you start spending money to chase performance that things are easier/cheaper using a factory turbocharged japanese sports car.
Must agree Birds. Performance mods for a Skyline would be cheaper/easier because there is heaps more of them in Australia. There is very few FTO's in Australia so you have the import factor and the rarity factor working against you. A lot of things need to be adapted from other cars. It took us 2 days to get a starter motor for the FTO. I finally found one at Jap Heaven in Melbourne (He'd got a GPX in over night so we were very lucky)
people actually like FTO's?? man never thought i would know anyone who likes them..well you learn something new everyday ey...
Love them! I was going to buy one before I got the Skyline. I may still get one if the Skyline dies. Excellent reliable cars with enough to please even the most picky of car owners. N/A 150kw more then enough for a P Plater,or someone who dislikes Turbos. Personally I'm not the hugest fan of turbo's just another part to screw up when some wanker boosts their car way to high. We had a Turbo Capri, and the turbo was totally shagged,and it had only had a new turbo put on it in about 2000 (was a showcar that someone had spent $65,000 AU on)
I don't mind FTOs. I nearly bought one until I realised how bloody slow they were! The handling is quite good though, and I normally hate FWDs with a passion.
If I was going to drive a girly looking lightweight car I'd take my MR2 turbo :P RWD > FWD
There not all "Slow" (GP's are slower then the others, Personally I wouldn't waste my time with a non-mivec GP FTO)
FTO's come in 3 models: GP, GPX or GPvR. GP's have 127kw from a N/A 2.0lt non-mivec engine in a car that weighs just over 1 tonne. GPX & GPvR is a Mivec 2.0lt engine (it's variable valve technology....think Honda's VTEC) with 150kw from a car weighing just over 1 tonne. Manual or Tiptronic (no such thing as a true automatic...only Tip). Tiptronic was still very new in 1994, and was seen as very technologically advanced. The cars were only built from1994-2000 (not because of flaws but due to them being limited edition awesomeness) What I think you're not considering is that they are N/A, they don't have a turbo to screw up when it's boosted incorrectly, no turbo lag, just preload the clutch and ZOOM! A GPX or GPvR in good running order should do 0-100 in 6.9 seconds.
It will take on and win against most cars. There is actually a video on U-Tube of it against a MR2, Supra, Levin, Integra, 180SX and a M3 BMW on a 5 lap race of Tsukuba in Japan.
It would eat my Skyline for breakfast (No surprises there because it's a GTv) however I haven't tried because I'm a good girl, and respect the road rules.
However it did eat my BMW 318I (once again not surprising) It killed my awesome 1.8 lt 83kw engine hauling 1.3tonnes of German tough machinary :)
  • Replies 191
Opps forgot my link :
and some awesome pictures too.
1st- my 1994 BMW 318i
2nd- FTO in poor lighting
3rd- The Turbo SA II Capri (Disturbingly ugly ex showcar...I hated that car. Was so pleased to see it go)
Edited by slinky-minky
Epic Boobs girl, AUS Spec.
the girl in the car is a mate of mine ill get her to send me some pics from her facebook of the stand she was modelling at she has hundreds
epic boobs hard lol
epic boobs hard lol
Lucky you!
Yeah I got pics of her, let me know if you / she wants any I can pass'em on to you / her.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
