Another job I've had to tackle was my idle control valving (AAC bullshit). I've converted to a Plazmaman inlet manifold and the latest version has a seperate adaptor plate that does not bolt to the bottom as per the earlier versions. Initally I was pissed off because it made it very hard to plumb all the hoses and electrical connections. I'd actually cable tied it to the firewall but it looked very ugly.
After speaking to Mark at Unigroup Engineering it turns out he was the one that told them to do it. With the older version you cannot adjust the idle without removing the AAC,,,how dumb is that. So after a lot of thought I came up with this.
I got Duncan to extend the sets of 2 wires, I made the bracket, bought some hoses from supercheap and removed the redundant rear wiper control unit.
Cheers
Neil.
It might be worth a trial run to delete the valve altogether. See if it can idle reasonably stable without the clutter. Race car. No a/c and presuming it's not being run with electrical loads from headlights etc.
Mine is blanked off at the moment as i killed 2 of them in the last year (one due to a broken engine mount though)... Idle is a bit ordinary but should come good with a quick tune up from JEM
It's a path I'm heading down. Simple is good. Provided it doesn't hunt really badly and stall.
Can confirm mine doesnt stall :)
It may sounds like a tractor at times though haha
I gotta tell you that I'm very very happy with them,,,for a race car they are perfect as they clear the roll cage intrusion bars beautifully. Michael did a great job. I attempted 3 times at making my own and I made crap. That all said they are not show car perfect but I never expected them to be. They cost me $430 excluding freight.
Cheers
Neil.
You don't happen to have the phone number to the place that made them by any chance? I wanna order some for my car.
I had spoken to Yavuz of UNIGROUP fame about removing all the AAC valving crap and got a reply of "Please Neil we are having enough trouble controlling your off throttle stalling problems while you are using that stupid atmo blowoff valve as it is, go to a plumb back one and we can do something". So for the moment I'll keep what I have and when the time comes for an engine re-build I'll go with removing all that complicated non race car shit. You 2 are right,,,simple is great as there are way to many hoses that are a potential issue.
I am running this turbosmart one by the way.
Vee Port PRO BOVs
Yep sure do mate "Mr Sheetmetal" 0754416099,,,Michael is his name. Now I was lucky that Dales doors were stiil there so he had something to go off,,, hope you have the same luck.
Cheers
Neil.
  • Like 1
Sell power fc
Buy something that has more power than. Commodore 64 and can run a engine
Stall issue fixed
I'm confused bitch,,, GM didn't make commodores in 1964,,,a quick google search says it was an EH Holden,,,should I plonk my drivetrain into one of those?.
The atmo BOV is a tuning nightmare on a RB engine so we went for the plumb back version of the same BOV.
Yuvuz was much happier and we have had no idle problems since he tuned it.
So on the weekend I thought I would finish removing as much weight out of the passenger door as possible. I still needed to keep some sort of structure so my window and locking stuff still worked properly. So that equates to a total removal of 3kg,,,nice,,,next weekend I'll attack the drivers door,,,a 6kg total loss in my eyes is fantastic.
I bought this tool from Hare & Forbes at their sale 2 weekends ago and I had a problem with the 1st one,,,it only did 10 holes before the hydraulic ram gave up the ghost. A quick phone call and a new one was waiting for me when I turned up on Saturday. Great service indeed,,,, I could have bought one off ebay but for the extra money their service was impeccable. It cost me $229,,,usually it's $275.
The 2nd one has cut 120 holes and loving it.
Cheers
Neil.
  • Like 1
jenna says you should buy a gtr
Jenna's always pissed off with you breaking shit,,,she would be even more pissed off if I bought one and build it properly on my tiny budget and handed you your arse.
I don't really want a 4wd drive tiger,,,I love rear wheel drives,,,you can't beat the fun of rear wheel steer.
LOL, I love the thinking you put into your car. I have gone down the same road with trying to get some weight out of the std doors :) I am loving dimple dies at the mo :)
Thanks Troy,,,I'm hoping to maybe take another few kilo's out now that I have this tool. Dimpling would be much better than what I'm using as cutting the thinner .9mm steel leave sharp edges. It's great when you cut thicker metal as it cut flush. Correct me if I'm wrong but don't you need the hole cut 1st and then dimple it?. Where and what diplling tool did you buy?.
Cheers
neil.
Yeh, holesaw first...and stolen dimple dies. They are about $300 for 1", 1.5" and 2' kits..easier to borrow but when my car gets its cradle back in and the spend slows will be grabbing my own so not to have to borrow gear all the time.
Holesaw sux balls as it leaves so much swarf and shit inside the door :(
Thought I might post some pics taken at Bathurst by a Pro,,,hope Eileen doesn't mind. Here's the link to her website for everybody to dribble over her handy work.
http://ebarlowphotos.com/
Cheers
Neil.
  • Like 3
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
    • The old approach was to fill the cylinder/chamber with a length of rope pushed in through the sparkplug hole. The new approach is to connect compressed air to the sparkplug hole and fill it with enough pressure to push the valves up. Doing either of these things with the head on and the engine in the car is a lot less pleasant than doing it properly.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
