Going off the position of the povit, being closest to the turbo. I'd say that is exactly how it works..
Be intresting to see if they become available to the public.. And what they cost..
Pitty they seem so large though..My turbo would be all most rubbing on my bonnet with that fitted under it.
Just like this :)
Sorry the link has pretty rubbish pics.
http://www.dieselpow...3t4-flange.aspx
Google turbine diverter valve for more images.
Edited by --Redwork--
  • 1 month later...
Looks nice, looking forward to hearing how this goes - what is the engine spec again? Is it being tuned on pump gas, or something alcoholic?
It's a Tomei 2.8l running 87mm bore,9.3:1 comp on E85. Has all the goodies to make the power.
Oh that's right, it all comes back to me - hadn't they (they being since demised units) already been run up and outspooled and outflowed the GT2871R-10s, at least while they lasted?
That's correct although I'm hoping these ones hang around a little longer. Wasted money on coating them if they don't.... :wacko:
They look like a pain in the ass to fit :(
Any reason why you didn't use a mettalic bend off that front turbo instead of silicone?
They become easier the more you do it....
No, other than when we first put them together we were under time restraints so just went with what was easier. Just using the same over this time again...
  • 1 month later...
Have you had a run on the dyno yet to see what power you got out of the new turbos?
No not as yet. When it was obvious we weren't going to make WTAC we took our foot off the pedal. Should be running in 2-3 weeks.
  • 1 month later...
I've set a time limit of end of November. If there are no 7064 .92's available, I'll get a GTX3067R with an ATP divided .82 housing or a Tial .63. Full Race should have T3 .82 7064's in stock now with T4 1.05's due in about a week and T4 .92's due about a week after that. I'll believe it when I see it.
  • 4 weeks later...
Happy to report back after my tuner has had a good play with the info from it.
It's just an optical sensor like the crank trigger.
A friend of mine has just installed the same on his RB, it was a first for Haltech apparently. Haltech spent sometime with both Ross and the tuner involved and loved the info from it. I believe they are going to write it into all their ecu software from now on.
i feel the same way. fortunately we've got tracking numbers now so the situation has improved
Just logged in to see if anyone has gotten the 7064 yet.
regarding 7064: the t3 singlescrolls have good availability, t4 twinscrolls shipping again
Happy to report back after my tuner has had a good play with the info from it. It's just an optical sensor like the crank trigger. A friend of mine has just installed the same on his RB, it was a first for Haltech apparently. Haltech spent sometime with both Ross and the tuner involved and loved the info from it. I believe they are going to write it into all their ecu software from now on.
good to hear things are working for you john, eager for you to get some seat time and finally experience the turbos at full song. btw did you guys get the ets-pro going
Edited by Full-Race Geoff
    • As I've said elsewhere, I am using the stock intercooler piping path in the engine bay, and a return flow cooler, and making ~250 rwkW (without any effort put into trying to turn it up past there just yet) and expect to be able to make some more, and frankly, I would be perfectly happy with 260-270rwKW. This is peak road Skyline usability territory. You go past there and, sure, the car will snap necks more when it's on boost, but it will also break shit all the time, cost a (even larger) fortune in tyres, etc etc. Anyway, I also do not like the over-the-fan pipe path, and you don't have to do it.
    • I see, honestly I’m not too fussed about the looks. The only reason to go plenum is to make the piping easier instead of the classic over the rad etc.
    • Not easy to quantify wrt something like how many fractions of a second slower it would be over 0-100. But given that a 250-300rwkW car is able to do that launch sprint in 5-6 sec (and faster with appropriate tyres, and surface)..... giving up as much as a second would feel like torture. A ~450HP capable turbo is not going to make lots of boost in the 2000-3000 rpm range. So, whilst with some boost on hand it will be faster accelerating in that rev range than your engine currently is NA, it will not feel like a fast car until the boost is solidly in. You know what your car feels like right now when you open it up at 2000rpm. if you've ever been in an actual fast car, you will appreciate that the NARB25 is.... not exciting. Well, add some boost and it will be better. But shorten the intake runners and it might not be better at all. It might come out better, but it could end up feeling the same. For me, it's not the 0-X km/h sprints that matter. It is easy to fry the tyres with anything over 200 rwkW. You can't use all the power available in 1st and 2nd anyway, you have to modulate the throttle. What matters is how the car reacts when you're driving in traffic in 4th or 5th and have maybe 2000 rpm on board, and you want/need to add some speed quickly, and don't have time for the downshift. It won't make boost, it will be all NA (at the speeds we're talking about - remember how fast you're going at 2000 in 4th! and don't plan on breaking the limit by too much.) So giving away NA torque is not what I would consider practical for a street car. And retaining that NA torque builds boost faster which makes the car faster. The flashy plenum is not actually better, unless you're looking at a track car where you can keep it on the boil all the time.
    • So how much difference does it make you think? Like 1 second in the 0-100?  I was have smaller turbo so hopefully that spools quick GTX2871.  currently it’s NA so you can imagine pretty slow, but I do want fast accusation a little as there’s not many places I’ll be driving where I go over 80 even near me. So 0-60 and 0-80 targets
    • Short inlet runners cost quite a bit. Dulls off the off-boost torque, and delays boost onset, because arrival of boost is driven by gas flow is a product of the ability to flow air which is torque. This is the reason that the stock manifolds have longer runners. On a 3L, or bigger, you can usually accept the compromise of giving away some torque because the extra capacity gives you a little extra to waste. But on a smaller motor, there's not a lot there to start with. Example, I swapped RB20 out of my R32, 25NeoDET in its place. The "wall of torque" that I experienced afterwards made it all worthwhile. That's because I came from RB20 land where torque is not a thing. But I would not do anything, anything at all, to reduce the low/mid torque I have now, because I remember what it is like to not have it!
