yes that is correct @harrisracing -- cut the end off and its a standard vband. the same as any Cummins/Holset turbo and many other BW or MHI turbos. There are cast 90 degree vbands available for this application but you could also just but a vband and weld the intercooler pipe to it
Hey Geoff, do you have these bends for sale? did not notice them on you website.
I might be interested in one of those vband 90 degree bends too. Or even just the vband to suit the outlet, I couldn't find them on the Full Race site.
Actually I also need an exhaust vband flange and clamp to suit an EFR8374 0.92 IWG turbo, an EFR boost solenoid pigtail and an internal wastegate canister heat shield (thats compatible with the single port Turbosmart actuators). Maybe you could do a package for us in Australia? :)
Edited by JustinP
Have you received any info regarding the new s400-sxe range ?
I noticed a SEMA 2015 video where a couple of reps from Borg Warner were talking about them. One in particular was an 88mm 10 blade compressor wheel with 1.15 a/r t6 exhaust housing.
Any indication on what will be available for a t4 exhaust housing? Seems to be a bit of limited information so far, but some have been listed on Jegs too. I was about to buy a s400sx3 until I saw the video - might as well hold out a little longer.
Thanks
Have you received any info regarding the new s400-sxe range ? I noticed a SEMA 2015 video where a couple of reps from Borg Warner were talking about them. One in particular was an 88mm 10 blade compressor wheel with 1.15 a/r t6 exhaust housing. Any indication on what will be available for a t4 exhaust housing? Seems to be a bit of limited information so far, but some have been listed on Jegs too. I was about to buy a s400sx3 until I saw the video - might as well hold out a little longer.
we have the all new 10 blade 72mm SXE in stock now. 110lb/min from a 72mm inducer is very impressive! the 88mm is approx 4-6 weeks out the last i heard. if youd like to email me at geoff[at]full-race[dot]com with the exact spec you are interested in, I will get you an update asap.
pics of the 72mm from our instagram feed this week:
12328438_1543820419248954_403538002_n.jp
Assume the 7163 aluminium chra is the same as the old 6758 indy car one...excluding the wheel diameters. Is there any possibility of BW supplying or producing them again?
sorry i do not understand your question?
Thanks. I was hoping they might have something in 76mm + compressor wheel / 87mm turbine. t6 is too big for my engine bay. Hopefully they will redo the 80mm or 82mm billet in the new compressor wheel configuration. I'll keep an eye out and send you an email when more info comes available.
  • 1 month later...
  • 3 weeks later...
Just got my car very roughly tuned in enough to make a decent 10 psi pull and I AM LOVING THIS TURBO!
Sounds frigging awesome, responds very well, seems to spool strong at around 3700-4k rpms (I'll log it soon). And I assure you I have a little lean spot on the bottom and I haven't touched timing yet, so I'm sure it will get better!
Quick little video.
Have you started the car yet?
if you mean me, not yet probably another month, still at work.
-10 AN to the REAR drain.
I'm using a Fullrace IWG manifold so the drain has a easy run between 1&2 runners
That turbo sounds sweet! looking forward to seeing it tuned ...you must have worked an all nighter to get that engine back together!
Good job!
BW 8374 EFR .92 iwg on 93 octane pump on Tomei poncam A cams, ported head, SS valves, hypertune V2 manifold, 8.5:1 CR, stock bores, 79mm stroker BC crank, 6 boost divided IWG manifold, Day 2 of tune...still not 100% by any means, cams not set at all (straight up zero on both)...
3rd gear pull from 2800 rpms:
5.0 psi boost at 3,077 rpms.
9.0 psi boost at 3,555 rpms
per Haltech log I just pulled. I'm sure there is more room here for better spool. I'm only set to 10 psi boost in haltech right now for break in and simple map tuning. I would tell you where it goes to 10 but clearly ecu is sending signal and causing slow rise around 9.5 psi.
Just thought I would share.
stock intercooler for now
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yep, its been down for a while, as I understand it it will be back soon.
