Tring to buy a R32 GTR RB26 front cut, only probably is tring to find somewhere to store it for a month or 2 without the wife finding out!!!
Any idea's
If my car doesn't sell soon i'll sell ya the 26 from mine with the loom to go straight into your stag.
Any idea's
Also bought some fancy brake fluid
Send wife? PO Box 2161 Boulder WA :) Or has this already been suggested? Sorry, haven't read whole thread.
OK.....I'll bite.
Cooling
HDI FMIC
Phenolic runner spacer
Nismo low temp thermostat
Custom(fisher) 3" intake
V35 manual radiator
Twin Trans coolers
TB spacer(lol)
Powerduct( :D )
catch can(s)
Turbo
High flow original to GT30/71
HDI EBC
Handling
Bilstein shocks
Eibach springs
324mm DBA rotor
R32GTR callipers with brackets
Hawk pads cut to size
Body
19" Lenso rims
R33 GTR N1 scoops
fully sic Nismo strips(custom fading ;) )
eyelids
Exhaust
Dump pipe....some japanese one
Complete Exhaust from Charlstone
ECU
Haltech platinum interceptor.....soon to go for a replacement reflashed ECU
Interior
Twin headrest DVD players
DTV
English conversion
On the horizon
Sway bars
Custom Airbox Suction pipe setup
Brembo's
Paddleshift's
Gearbox rebuild with stage 2 shift, 3,500 stall(depends on reflash outcome) and MVB
Bonnet pin's so I can lock the bonnet closed and give the key to my wife to STOP ME!!!!!!!!!
Edited by Jetwreck
I put the new cover on the motor, just got it back from the powder coaters.
unfortuntely at the same time I found the old cam breather hose had a split so it has a temporary blue replacement.
That looks awesome
That looks awesome
I'm guessing you don't mean the crappy blue breather!
Great work again from Craved Coatings on the cover... I picked up the cover on SAU, it was hand sprayed from a can. Craved sand blasted then powder coated in in crinkle finish black - looks mint :P
I was gonna ask where you got that coilpack cover from, Duncan - good find!
And yeah, Chris @ Craved Coatings is doing some awesome work, and he's definitely putting the hard yards in! I think he sleeps (much) less than I do!
I finally got rid of the stock exhaust, to replace it with a 3" X-Force stainless steel system, with a new dump pipe and 3" high flow cat con.
The guys at C-Red even gave me a silencer with it if the neighbors complain ^_^. Idont know why i didnt do it sooner! ^_^
That black bit on the cam cover is dear as poison. Just got one from Nissan. Nearly $40.
Luv that cover.
Edited by 66yostagea
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
