i'll find a black pair and chop them on and repost
was thinking black but that thread with the jap stageas at the track had a yellow s2 with white wheels and it looked good
Just painted my front headlights!
Chris.
Very nice indeed :3some:
I know a couple of people who want to do that pretty badly :)
Replaced the power steering fluid with Nulon 100% Synthetic ATF, replaced the lower weather shields on the front doors (finally!), gave it a clean yesterday.
Chris.
love it they look fkn great!
Just brought mine back from the car wash...
Oh, and I changed one of the map lights - both were still working, but one was really dim.
Nick stop going all out with ur car dude, or soon ull have to enter autosalon....
i,ve not long had mine, figure i'll wait for things like the turbo to go before spending up on them but it came with r33 four pots on the front, i tinted the taillights and removed the nissan and stagea badges off the rear, got a gps traker alarm with remote shutoff and a blitz cat back exhaust and high flow cat which aren't installed due to the lack of a dump pipe but i's coming lol :)
Yesterday I cleaned the engine bay and gave it a good wash. Today I'm gonna hit it with Mothers Clay Bar and then Meguirs Gold Class Wax. Should look awesome :(
Also, just bought an Innovate wideband O2 sensor that should arrive tomorrow. I'm gonna wire it in to my Vipec ECU and leave it in the car pernamently. Can't wait to play the tune :( Just gonna try and lean out the low-load everyday driving parts in the search of better economy.
just went under mine on the hoist with a torch and a bore scope, and found a few loose fittings, a stuffed tranfer case seal, a loose tailshaft, a leaking coolant seal on the front turbo and a loose front cradle.
Hopefully this afternoon I'll be saying I picked it up with all issues sorted! :(
i finally made a heat shield for my pod
went to foamland (dodgey tassie version of clark rubber)
bought 0.5mx~1.0m of foam with a foil backing for $13.75
got the stanley knife out and started hacking away
ended up with about a .4x.5 m piece left
doesn't look pretty but seals around all the pipes and things well and looks like this:
i'll add a cold air feed in when i get a chance/can be bothered
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
