Get some neg camber on that sucker - STAT!! 4mm different offset than mine (+22) and your's is full mexican!
I fitted my bluetooth adaptor for the headunit, so now I can take and make calls without worry of getting busted on the phone.
i will hit the coilover soon enough if i put too much in... its got like 1.5 degrees now so NOTHING... just lipped the gaurds more and not touching at all anymore :)
they were +30 with a 5mm spacer.
So that confirms the ideal M35 fitment as 9.5 +35 offset.
Oh and they look insane! so tough!
come again?
if they were +30 and he added a 5mm spacer, that would mean that they are now sitting effectively at +25
or if they are +35 with a 5mm spacer then they would be effective +30
etc
finally got around to aligning mine, and very happy - exactly what i wanted (well maybe closer to 3 deg neg on front but 2 is fine) :P
18x9.5+2
18x9.5+1
front -2 deg camber
rears -.5 deg camber
how the driveway go mike?
yeah not too bad, no dramas getting out and only a little bit of rubbing from the front bar getting in surprisingly.
the wheel aligners was another story.. had to have a couple of blokes push me up their driveway cos i got beached sea-sawing :ph34r:
I accidentally bought some wheels when I went to get a fresh set of tyres... 19x9.5 +35 with 5mm spacer on all 4 fit peeeeerfect.
I will get some better photos soon.
NICE!!!
might have to do my headlights soon!.....once I stop buying other parts!!!
LOL @ "accidentally" bought new wheels...
lol I just accidently bought a 15g R33 GTR
going to sydney soon to pickup
must sell the track car now
currently fitting wilwood brakes, to put the brakes back on the r32.
might end up selling the stagea if I enjoy the gtr too much. or vice versa
Well it seems I need a different loom and a relay of some sort. :D
do you mean you're putting in the little motor that helps close that last little bit or the one where you push the button and the whole tale gate opens and closes?
if its the latter, where did you get it from and how much? i like gadgets :P
Well it seems I need a different loom and a relay of some sort. :wub:
If you can get a part number (and a picture) for the relay i have a box full of relays and resistors and other odd little electrical boxes left over from my wrecked car!
    • I think in the modern era we live in, if I were converting a hydro lifter head to solid, particularly when chasing revs, I'd be seeing what I could do to use shimless buckets. Those of us with Neos usually have this persistent niggling fear of a shim getting spat out and ruining everything. Shim-over is...yucky that way. At least the Tomei kit appears to be conventional, but it would still be nice if they'd decided to go shimless.
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
