I finished the new exhaust today, thanks Cam for helping. :woot:
I managed to keep the pipe as straight as possible given the tight space to work with. 3.5 inch dump (flattened for clearance) into 100cpsi cat and 3 inch front pipe. The rest of the system is Cam's old 3 inch one, Legalis is it? It still sounds louder than I want... The price you pay for a performance exhaust I guess.
Have yet to drive it so I will let you know my thoughts tomorrow, I will also have to get back on the dyno and tune for this and the boost controller so hopefully good gains. :woot:
NICE!!!
Thats hot scotty.
PM about your old exhaust. Keen on making another one of those front/dumps?? Ill buy one...
Lol, If you buy the old system wont you be jealous when your brother rips one of the new dumps out? :woot:
I can make more of them but you can only imagine how much time that many welds takes. I haven't priced them up but they wont be cheap... Also, they are a bitch to fit. What's your tool selection like? It could be worth a trip down.
nice exhaust, good that you gave it a go yourself dude... rather than paying a pro to do it...
the welds are okay for a beginner...
did you really have to "flatten" the front for clearance? liek the 3inch wouldnt fit at all?
interesting concept, although i will be doing mine a little differently.
but seriosuly kudos for doing it yourself, love your style
when i finally decide to do mine. which shouldnt be too long away...
i only got my car friday and its not complied yet lol
ill be able to make more for anyone who wants one... and i wont be charging much, if anything at all...
ive made 3 or 4 custom intercooler kits for ppl when i was in the drift scene. and i only charged like 50 bucks labour. and they had to pay for material. (trying to help ppl out)
where i work we make huge ginormous tanks and vessels. for CSL (who make the drugs and vaccines for everyone) and food tanks... so all we do is bust our ass, and then the truck comes and picks it up.
and thats it. we dont ever get to see the customers reaction... so because when i do stuff for peoples cars. i get to see thier reaction i almost feel bad charging them lol
Edited by bLaQ.bOi
I finished the new exhaust today, thanks Cam for helping. :down:
Have yet to drive it so I will let you know my thoughts tomorrow, I will also have to get back on the dyno and tune for this and the boost controller so hopefully good gains. :)
Anytime mate.
Still louder? How does the Mrs feel about the sound & volume?
How did it sound when warm (it is a bit loud when cold - as is the Nismo exhaust for that matter)
Anytime mate.
Its almost silent at idle and cruise but as I get on the gas it becomes much louder, old system was the other way around.
I had to lower the boost back to stock for now as its running leaner again. I have booked some dyno time for Thursday.
Mrs likes it. :P
Mrs likes it. :P
damn that bottom under-window wing looks great!
attempting to fit longer wheel studs - wrong knurl size!!!
M12x1.25 50mm long studs with 13.75mm knurl wont fit
going to try 12.75mm knurl
expensive $100 mistake :P
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
