got my alignment done
can someone have a squiz and tell me if the messed anything up?
i asked him to dial in as much caster as possible and he seemed confused and said "i don't think you will notice that on road tyres mate"
Thanks
Were you in Tassie?
H
Faark dude, even with my best squint I can't read that properly, hope someone's got better eyes than me. I'll have 6 beers and come back to it.
Around +5 deg 22" left, +4 deg 41" caster; -1 deg camber and +0.5mm toe was optimal on my old r31, and it needed camber/caster adjustable strut tops to get there; obviously there'll be some differences given the rear can also be aligned. How were they adjusting the caster? Are your caster rods adjustable?
On my NM35 they're not...
I.ll scan it in, didn't realise the quality was so bad
Installed an 8 point earthing kit and, yes, including the transmission bracket when earthing an M35 makes a bit of difference to gear shifts (still nowhere near a shift kit obviously)
Edited by iamhe77
dropped mine at the workshop to finally get the revalve kit for the front shocks fitted: hopefully handles like a demon again once I get it back...
All that's left now is to get the roof rail replacement kit fitted and painted, than tidy up the engine bay...
compression test yesterday :(
#1 - perfect :D
#2 - perfect :D
#3 - prefect :D
#4 - perfect :D
at this point I thought I had dodged a bullit and I may just have to replace plug's
#5 - perfect :down:
#6 - F#$king nothing :(:(
P.S.anyone want a cheap root....need cash quickly....spooning after is extra!
Edited by Jetwreck
#1 - perfect :D
#2 - perfect :D
#3 - prefect :D
#4 - perfect :D
#5 - perfect :down:
wang some oil down that bore, if it comes up then its the rings orring lands
if it stays down then its in the head which would mean that you don't have to rebuild the block
rnd 3! the first settings on the front are way off cos i changed the steering rack ends
and aster is adjusted with the stock bushes, you only get a tiny bit of adjustment tho
Edited by pipster11
am i lining it up correctly, does that say -16.96 degrees left and +3.02 Degrees right for caster?
yeah, might ask them about that cos it still pulls a tiny bit to the left (no road camber correction) but i guess they only measured the caster on one side?
Here is my suspension settings recipe. You obviously can't get this amount of castor without adjustable arms so i have adjustable castor arms and adjustable rear camber arms. Can't afford the front camber adjusters at this point. You can get a small amount of adjustment with eccentrtic bushes. The value of lots of castor is straight line stability at high speed. If you can't get as much as you want you want them at maximum and then back off rhs to 1/4 degree less than lhs.
Nissan Stagea RS4T
Front
Caster Left positive 6 degrees
Right positive 5.75 degrees
Camber Left 1.0 degree negative
Right 1.0 degree negative
Toe in Left zero
Right zero
Rear
Camber Left negative 0.5 degrees
Right negative 0.5 degrees
Toe in Left minus 2mm
Right minus 2mm
There has to be an error in the print out. With that much + caster on the left and so little on the right it would be undriveable.
You would probably find your wheel hitting the rear of the wheel arch on the left side and the front of the wheel arch on the right.
Stagea is in the shop getting GPS tracking fitted to compliment the alarm/kill switch/club lock. f**k thieves! :rofl2:
Goes for a dyno tune next week. Aiming for 220-230 awkw from the stock injectors :cool:
Then next is Z32 afm and 550cc injectors.
Stagea is in the shop getting GPS tracking fitted to compliment the alarm/kill switch/club lock. f**k thieves! :cool:
Goes for a dyno tune next week. Aiming for 220-230 awkw from the stock injectors :ninja:
who's fitting up the gps tracking? can ya PM me with a cost, with the amount of imports getting stolen in Adelaide lately, i'd def be keen to get some fitted to my off road stagea!
ready for motor out......1 hours work to remove the whole front of the car....gotta love M35's :)
Good effort! Shit, you dont mess about do you :P Is it repairable, or will you be sourcing a new engine?
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
